Wed, Jan 15, 8:06 AM CST
Poser - OFFICIAL F.A.Q (Last Updated: 2025 Jan 15 2:13 am)
Subject: Small question about saving V3 Injection MORs
SnowSultan ( ) posted Fri, 01 August 2003 at 1:32 PM · edited Wed, 15 January 2025 at 7:57 AM
Hi. This question may have come up before, so I apologize in advance if it's been answered more than once. :) Can someone explain (if it's even possible) how to create a MOR file for Victoria 3 that includes body part scaling, morph injection data, and PBMs (like adjusting the "Heavy" body morph dials only on the arms and not with the Body's dial)? I know how to make a MOR that will include injection data, but the scaling is never saved and the PBMs don't always do what they're supposed to for me. ; Any help would be appreciated. Assuming I can get this solved and working OK, I plan on making the end result freely available. Thanks for your time, take care. SnowS
my DeviantArt page: http://snowsultan.deviantart.com/
I do not speak as a representative of DAZ, I speak only as a long-time member here. Be nice (and quit lying about DAZ) and I'll be nice too.
Jaager ( ) posted Fri, 01 August 2003 at 1:51 PM
You need to work off of the CR2 that has your figure defined. IBP has options to include scaling. With the F6 hotkey, you don't need to reload the file after you alter options - if what you have is not what you want. As far as having individual PBM set, I think that should save unless you have - Master channels only - as an option. I think Rob was going to offer the opposite of this - look at figures that have individual PBM set instead of the master and translate that to the master - but that may be for a future version. I have not seen anything about selecting a value for the master - since often, these sort of figures have different values for instances of the same morph and you need to choose which to use for the master.
SnowSultan ( ) posted Fri, 01 August 2003 at 1:54 PM
Can you tell me what IBP is? That doesn't sound familar, and I can't really understand the rest of your explanation without knowing that. ;) Thanks.
gildedgecko ( ) posted Fri, 01 August 2003 at 1:57 PM
Attached Link: http://market.renderosity.com/softgood.ez?ViewSoftgood=21551
Oooh! Oooh! Oooh! *jumps out of seat excitedly waving a hand in the air* DarkWhisper's new Injection Magic program does it automatically! I've tried it and it works! Did about three days' worth of CR2 editing in about 20 minutes total for four characters. I have DAZ's Injection Pose Builder, too, but Magic is definitely better.
Jaager ( ) posted Fri, 01 August 2003 at 2:16 PM
IBP is InjectionPose Builder from DAZ, it is $2 or I guess $1 now - from PC. It is Rob Whiz' creation. Although 'Recursive Batch' is not a phrase I had occasion to understand before, I means that the program will also automatically convert every file in a folder, if you have a batch to process. It coverted one of the V3 50 head shape folders into individual INJ/REM poses in about 5 min. The orginal had a master INJ and 50 pose files. This way - only the required morphs are injected for each face.
SnowSultan ( ) posted Fri, 01 August 2003 at 3:46 PM
Ah, thanks for the answers so far. I was just looking at InjectionPoseBuilder yesterday but didn't make the connection. For 99 cents, I'll probably give it a try. ;) Thanks very much, I'll send you guys an IM a little later with a link to a little something to download for your trouble. :) Take care. SnowS
Placido ( ) posted Fri, 01 August 2003 at 7:28 PM
Maybe i suggest MorphManager 4 , (like jagger...) , with MM u can save ur two and maybe hundred morph with one dial only , but dont distribute if they built from DAZ Morph I dont know thats make ur character load faster or not , but i think i love One dial morph thankz
