Forum Moderators: Staff
MarketPlace Showcase F.A.Q (Last Updated: 2025 Jan 25 7:54 am)
Thanks Cin ;-), actually I found the template and model it's self very easy to work with ... no stretch or pull anywhere, even when using the male morphs. The only trick was making sure that I copied the template onto a layer above the base layer and then turn it 45 degrees, (you will need to make the canvas size bigger to do this) .. once you are into the fitting stage just link all the layers together and turn them back 45 degrees .. copy merge this .. then paste it onto the original template and it should be fine. (not that you asked g but maybe it will help ?). The area I had problems was more to do with design and what the dresses would actually looke like , that was were Anton's help was so important, he had a lot of Egyptian textile information and I spent a long time on the phone with him picking his brain.
Beautiful textures Laurie!
What we do in life, echoes in eternity.
E-mail
| Renderosity
Homepage | Renderosity
Store | RDNA
Store
These are awesome picked them up earlier :O)
Sandy
An imagination can create wonderful things
SndCastie's Little
Haven
I am simply overwhelmed with the whole set of Egyptian products that went up at the Platinum Club this week. These textures are so skillfully made that they give the illusion of real fabric. They LOOK like finely pleated linen. Superb work, Laurie! May I ask what textures Victoria 3 is wearing in the promo pictures? Kimberly
outfits up at Daz now...in the PClub .. hope you like :-).A big thank you to Anton for all the help he gave me with these!!!
Also Anton has a wonderful Egyptian prop pkg up that co-ordinates with the outfits.
Lisa has some fantastic textures for the Studio Props pkg and a set of poses for the same props up as well.
