Poser - OFFICIAL F.A.Q (Last Updated: 2024 Sep 19 11:01 pm)
It sounds like you have quartanian or loop turned on.. turn that off first.... when you hit an end point in teh movement.. set a keyframe.. move it about 2 frames then set another keyframe. that'll help in preventing excess movement. usually at the end of every movement set a key frame... Poser likes to interpolate where it thinks you want to go.. and usually messes up a bit. 8 ) I hope this helps... the only other thing is that it's a lot like model animation ala Harryhausen. stop motion. Cheers
Attached Link: http://www.philc.net/swingzone2.htm
At the end of an animation segment you have probably already set a key frame which would be correct. Now select that frame and hit the Break Spline button in the Animation Palette. This will prevent the next segment influencing the previous frames and visa versa. As an example you may like to get my free 190 frame Hand Jive pose. You can see from that how I have set key frames with broken splines to isolate each segment of the dance.This site uses cookies to deliver the best experience. Our own cookies make user accounts and other features possible. Third-party cookies are used to display relevant ads and to analyze how Renderosity is used. By using our site, you acknowledge that you have read and understood our Terms of Service, including our Cookie Policy and our Privacy Policy.
