Sun, Feb 16, 11:53 PM CST
Poser - OFFICIAL F.A.Q (Last Updated: 2025 Feb 16 10:02 pm)
Subject: 3Delight plugin for Poser 5
  • 1
  • 2
stewer ( ) posted Sat, 02 August 2003 at 12:25 PM · edited Sun, 16 February 2025 at 11:33 PM
Attached Link: PoserMan
Sorry for the repost, but getting only one response on the last try made me think I did not chose a thread title compelling enough, or whatever I wrote in the thread was too scary. Back on topic: I would like to inform you that I have released a preview version of my "PoserMan" script which embeds 3Delight as an external renderer in Poser 5. Please not that since it is not finished yet, I cannot please you with promises for instant jawdropping renders, but I can tell you that it has such nice features as background rendering of animations and the export of Poser's dynamic hair and clothing. I thought it would be too unfair to keep such a thing for myself. I would love to get some feedback from you, at least to tell me wether it works on your computer or not (as I might have forgotten to include a file in the archive). Thanks for your attention, Stefan
stewer ( ) posted Sat, 02 August 2003 at 12:31 PM
Attached Link: 3Delight
Here's the link to 3Delight, which is required (and a free download). I would like to add that my script should in theory work with other RenderMan compliant renderers too, for example Pixar's PRMan, BMRT, Aqsis, RenderDotC or Pixie. This may or may not require you to modify the script.
ford3auss ( ) posted Sat, 02 August 2003 at 12:48 PM
Hi stewer, i just downloaded your program and run it, it set it up in my c drive, how do i open it to use it im lost... lol...
stewer ( ) posted Sat, 02 August 2003 at 12:50 PM
You downloaded 3Delight....that's OK, but my program is a ZIP file (the first link). It comes with instructions in the ZIP.
ford3auss ( ) posted Sat, 02 August 2003 at 1:05 PM
HI.Yes i downloaded it and it a exc file... what am i doing wrong..
quinlor ( ) posted Sat, 02 August 2003 at 1:08 PM
Sounds very cool! I hope, I find the time to try it soon.
stewer ( ) posted Sat, 02 August 2003 at 1:12 PM
Attached Link: PoserMan zip file
ford3auss, you need to download another file. You can find it on the web page behind the first link, or just use the direct link here.
The Zip file contains a Readme.rtf with further instructions.
ford3auss ( ) posted Sat, 02 August 2003 at 1:22 PM
Look sorry about all that, i just got it thx for your help mate, dam it does some fine renders...cya
stewer ( ) posted Sat, 02 August 2003 at 1:26 PM
No problem. I should have made it a little clearer that one needs to download two files.
atz3 ( ) posted Sat, 02 August 2003 at 1:39 PM
when I run the script iget this error message. Traceback (most recent call last): File "", line 242, in ? File "", line 82, in init AttributeError: RayTraceShadows the rib file is created but 3delight doesn't launch any ideas?? zach
stewer ( ) posted Sat, 02 August 2003 at 1:55 PM
atz3: sounds like you haven't SR3 installed. My script is using some SR-3 only Python methods.
atz3 ( ) posted Sat, 02 August 2003 at 1:57 PM
that might have something to do with it... I'll give it a shot! thanks!! zach
c1rcle ( ) posted Sat, 02 August 2003 at 2:00 PM
This is what I got Traceback (most recent call last): File "", line 242, in ? File "", line 230, in init File "RuntimePythonlibos.py", line 387, in getitem return self.data[key.upper()] KeyError: DELIGHT is there some particular place we need to have 3delight installed? like maybe the poser5 folder itself?
c1rcle ( ) posted Sat, 02 August 2003 at 2:02 PM
ps it created the rib files first, so that part of it is ok for me too :)
ford3auss ( ) posted Sat, 02 August 2003 at 2:03 PM
Dam its takeing a long time for something to happen on my pc. is that normal. im running a AMD 1.1 with 512 of ram....
ford3auss ( ) posted Sat, 02 August 2003 at 2:06 PM
it just finished runing the script and nothing happens?????
c1rcle ( ) posted Sat, 02 August 2003 at 2:06 PM
it took about 20-30 seconds to create a single rib file on my machine, 2.0Ghz P4 & 1Gb Ram
ford3auss ( ) posted Sat, 02 August 2003 at 2:07 PM
3delight doesn't launch...lol
c1rcle ( ) posted Sat, 02 August 2003 at 2:09 PM
where did you install 3delight? just wondering cause mine is installed in c:3delight
stewer ( ) posted Sat, 02 August 2003 at 2:10 PM
c1ircle: No, it does not need 3Delight in a special place. But they key error says that the 3Delight installer did not set some system variables. What OS are you on? If you're on 2000, you might need to do this: http://www.3delight.com/ZDoc/3delight_7.html#SEC7 ford3auss: It is exporting all the frames, so if you have long animation it will take a while. Set the animation lenght in Poser to 1 if you want only one frame export. If you don't want to use animations at all, open the Python script in a text editor and change "ANIM = 1" to "ANIM = 0".
stewer ( ) posted Sat, 02 August 2003 at 2:13 PM
ford3auss, did the script create the RIB files correclty? Are there any other files in the same directory? Export time really depends on your scene complexity. The script will also convert the textures to the tdl format that 3Delight requires, so if you use lots of textures the following exports should be faster (until you delete the .tdl files).
stewer ( ) posted Sat, 02 August 2003 at 2:15 PM
And thanks for your testing so far! You're a great help! Don't worry about your machine specs, I wrote the script on a 1GHz P3 w/ 512MB RAM.
ford3auss ( ) posted Sat, 02 August 2003 at 2:34 PM
Im back, well this time i saved to a folder on my desk top,and i ended up with this, any ideas, and i changed the "ANIM = 1" to "ANIM = 0". it was a lot quicker, but 3delight doesn't launch. I just used standard Don with standard tex.. It allso but a rib file in my folder on desk top...3delight is on cdrive..
c1rcle ( ) posted Sat, 02 August 2003 at 2:36 PM
that did the trick :) rebooting after you install something helps too. The renderer seems a lot quicker than poser itself, are you planning to add the smoothing to this in the future? ps I think there's a problem with the ebots as I never saw your original thread or I'd have been all over it like a rash ;)
ford3auss ( ) posted Sat, 02 August 2003 at 2:41 PM
pic sorry
stewer ( ) posted Sat, 02 August 2003 at 2:43 PM
Hm...strange. So it doesn't create a TIFF file either? No output messages, no command line windows popping up? Did it create the .tdl files? Can you try this for me: Open a command line and enter "renderdl --version", then press enter. What does it say then?
stewer ( ) posted Sat, 02 August 2003 at 2:49 PM
c1rcle: Yes, smoothing is planned. In fact, I have subdivision surfaces in the script already, but that interferes with the materials right now. I have to work on it a little more. Also, I plan to add the other missing features too, namely bump, environment and transparency mapping. I'm not sure if shadow maps are easy, and very cool would of course be ambient occlusion or some other global illumination feature.
stewer ( ) posted Sat, 02 August 2003 at 2:52 PM
ford3auss: Can you try a simpler scene? E.g. just the stick figure or a couple of props.
c1rcle ( ) posted Sat, 02 August 2003 at 2:52 PM
so far it looks great :D can't wait for the extra features, thanks for creating this :)
stewer ( ) posted Sat, 02 August 2003 at 3:00 PM
If you want to, you can open the script in a text editor and set POINTS and SUBDIV to 1 to take a look at subdivision surfaces.
ford3auss ( ) posted Sat, 02 August 2003 at 3:03 PM
I did a reboot and reinstal and this is what i got, it fully renders and vanishes, lol, well hope you can work it out, im running XP Pro
stewer ( ) posted Sat, 02 August 2003 at 3:07 PM
The render window is not supposed to remain open, it's just to show progress. When it's finished, you will find a TIFF file in the same place as your RIB file.
Paoli ( ) posted Sat, 02 August 2003 at 3:27 PM
Cool!
ford3auss ( ) posted Sat, 02 August 2003 at 3:59 PM
Im back it saves the RIB file but i have no TIFF?????
stewer ( ) posted Sat, 02 August 2003 at 4:07 PM
I see in your shot that it says "rendering "0.rib", which means you didn't give it a file name, that could be a problem. Try giving it a filename.
atz3 ( ) posted Sat, 02 August 2003 at 4:10 PM
I have rib files but no tiffs also. updated to sr3. rebooted. no error messages now. no renders either. win xp. renderdl ver 1.0.6 (july 29 2003) "beta 2"
PabloS ( ) posted Sat, 02 August 2003 at 4:13 PM
ford3auss ( ) posted Sat, 02 August 2003 at 4:27 PM
Even if i give it a file name still no TIFF just a RIB..it allso dumpes other files on my desktop. Its like it does 3 renders....i just called my save file 3Delight, it puts the RIB in there and the other file on my desktop,3Delight folder is on desktop,,,,
ronstuff ( ) posted Sat, 02 August 2003 at 4:36 PM
Great work stewer! The possibilities are very exciting.
stewer ( ) posted Sun, 03 August 2003 at 2:33 AM
atz3, ford3auss - can one of you open such a RIB file in a text editor and see if it has a line "Display "tiff" "rgba"" at the beginning? You could also try a file search for that tif file, maybe 3Delight has put it somewhere else. Also, you may try running 3Delight from the command line, "renderdl -D "
stewer ( ) posted Sun, 03 August 2003 at 2:35 AM
Ah...I have one idea what it could be: Try using a directory that is not the Desktop or My Files. It could be that my script is choking on spaces in filenames.
markdc ( ) posted Sun, 03 August 2003 at 4:24 AM
Thanks for making this stewer! I got it to work but it seems that it won't render hair (I tried koz short hair and Nissa hair). -Mark
markdc ( ) posted Sun, 03 August 2003 at 4:26 AM
Tempus Fugit ( ) posted Sun, 03 August 2003 at 5:45 AM
stewer ( ) posted Sun, 03 August 2003 at 5:55 AM
Mark: It doesn't do transparency mapping yet, which I suppose your hair is using. You'll either have to stick to "plastic hair" using no transparency mapping or use Poser 5's dynamic hair, for which basic support is included as mentioned in the readme file. That's one of the reasons why I am not considering a full-featured release yet, hence the name "preview release 1". While it's nowhere near being a replacement for production quality renders in FireFly, I thought it could be useful for quick background animation previews already. Of course, getting a better quality out of my epxorts is something I am pursuing.
VI_Knight ( ) posted Sun, 03 August 2003 at 7:46 AM
would this work on P4?
stewer ( ) posted Sun, 03 August 2003 at 8:08 AM
I suppose the script could be ported to ProPack. Poser 4 without ProPack has no Python support, in this case you'd have to use Poser's built-in RIB export and launch 3Delight separately.
VI_Knight ( ) posted Sun, 03 August 2003 at 8:38 AM
Yes I have P4 PP. I was just wondering b/c I only saw mention of P5.
stewer ( ) posted Sun, 03 August 2003 at 8:49 AM
The script won't work with ProPack in its current form, as I am using some Poser 5-exclusive Python calls. Also, the version of cgkit I use requires Python 2.2, and I don't know if there's a version that will work with ProPack's Python 1.5.3.
VI_Knight ( ) posted Sun, 03 August 2003 at 10:35 AM
Thanks for clarifying. Any plans to make it available for P4 PP?
  • 1
  • 2
