Sat, Jan 11, 5:58 AM CST
Renderosity Forums / Carrara
Welcome to the Carrara Forum
Carrara F.A.Q (Last Updated: 2025 Jan 10 10:15 am)
Carrara Free Stuff here.
Subject: Carrara 3 Photorealistic Renderer problems?
goofball ( ) posted Sat, 02 August 2003 at 3:53 PM · edited Sat, 11 January 2025 at 3:44 AM
I tried rendering an image using indirect lighting, the full raytracing feature with raytraced soft shadows, and light through transparency. most of the image looks fine except for a few of the shadows. all of my detail setting where set at the highest and I can't figure out why there is pixelization in a few of the shadows. I know its not the texture map, that holds up fine but some of the shadows have pixelization. If anyone has any ideas please let me know. Thanks.
GabrielK ( ) posted Sat, 02 August 2003 at 4:51 PM
Were the shadows being cast by hair or lashes? I've noticed that in some of the pictures I've tried rendering as well. Then I remember reading a post or maybe it was a tutorial that mentioned something about it. Basically it said to check the "interpolation" box in the shader where you have your transparency map set. I can't remember where I read that or I'd point you there, but it seemed to work for me.
goofball ( ) posted Sat, 02 August 2003 at 5:49 PM
Thanks for the info, I just tried that, it did help but there is still pixelization. Any other suggestions?
Kixum ( ) posted Sat, 02 August 2003 at 7:37 PM
I've done quite a few studies on the new soft shadows. Make sure you turn up the settings in the shadow options for the light source. I get similar results with what you have when they're set to default. -Kix
-Kix
