Thu, Feb 13, 3:00 PM CST
Poser - OFFICIAL F.A.Q (Last Updated: 2025 Feb 13 2:12 pm)
Subject: 3Delight plugin for Poser 5
  • 1
  • 2
stewer ( ) posted Sun, 03 August 2003 at 11:28 AM
Not really. I haven't used ProPack in months.
markdc ( ) posted Sun, 03 August 2003 at 2:28 PM
stewer, I thought that was probably the issue (just wanted to check). Thanks again. I hope you'll continue to develop it. -Mark
ford3auss ( ) posted Sun, 03 August 2003 at 5:02 PM
Hi mate, i just tryed using a directory that is not my Desktop or My Files, and the same problem, i opend the RIB file in a text editor, i will post it so you can see if it all right..thx for your time...
stewer ( ) posted Sun, 03 August 2003 at 5:17 PM
See the file path in line 6? That is where your file should be. However, that path still has spaces in it, so you better try something like C:temp or the like. I will try and get an updated version online soon that won't choke on spaces in file names.
stewer ( ) posted Mon, 04 August 2003 at 4:44 AM
Here's an updated script that should be able to deal with spaces in file names. Unfortunately, I'm away from my Windows box right now and can't test it, but if someone could try and report back so I can upload it. (download the file, rename it to poserman.py and run from within Poser 5) Thanks.
c1rcle ( ) posted Mon, 04 August 2003 at 7:49 AM
seems like no-one else is about right now, so I thought I'd check it for you. Works perfectly with the spaced out folder names (saved the rib to keindesign folder with the py file) how'd you get the subdivision to work on the script? I changed points & subdiv to 1 but it just gave me a great long list of floating points it was missing & stopped.
stewer ( ) posted Mon, 04 August 2003 at 9:50 AM
Thanks for testing, c1rcle. Well, the subdivs - could be that they're broken in the current version, quite possible. Once I started working on the materials, I disabled the subdivs and didn't test them since that. I probably changed something in the meantime that broke them.
c1rcle ( ) posted Mon, 04 August 2003 at 9:57 AM
ok I'll just have to wait patiently like everyone else then ;)
ford3auss ( ) posted Mon, 04 August 2003 at 6:38 PM
Hi mate im back, its working now thx, saveing to a folder on my desktop, it saves the rib and tiff to that folder, im running your updated script, and i allso did your system variables thing, im running Win XP Pro...one last thing it still dumps the 3 tdl files on the desktop, is that normal???. Thx for your time...
stewer ( ) posted Tue, 05 August 2003 at 12:07 AM
Yes, the .tdl files are normal. These are the textures of your scene, converted to 3Delights own texture format. 3Delight cannot read most ordinary image file formats like jpg or png, that's why the tdl files are necessary.
atz3 ( ) posted Tue, 05 August 2003 at 2:59 PM
works for me now too. thanks
stewer ( ) posted Tue, 05 August 2003 at 3:04 PM
Cool. The zip file on my web site should contain the new file now. Thanks for testing so far! I will start a new thread when I have a newer version out, happy rendering until then!
TimeStalker ( ) posted Fri, 12 September 2003 at 7:17 AM
I've tried the script, very, very nice. I've found a problem with the near clip plane, when the camera is close to face.
stewer ( ) posted Fri, 12 September 2003 at 7:44 AM
What is the problem exactly? Does it also occur when you export the same scene as RIB via Poser's File/Export? Did you try other renderers like Aqsis or BMRT?
  • 1
  • 2
