Sun, Feb 9, 7:22 PM CST
Subject: rendering error messages
ssgurl ( ) posted Sun, 03 August 2003 at 6:16 PM ยท edited Tue, 04 February 2025 at 2:59 PM
i have been receiving an error more and more often when I try and render. even tho i have 4 gig free on the drive where poser is installed and another 4 gigs free on the drive where i am saving the render, i am told that i have "insufficient disk space to render at the current resolution". =/
SamTherapy ( ) posted Sun, 03 August 2003 at 6:58 PM
From CL website: "Poser 4 can't render high resolution images. Error appears "Insufficient disk space to render". After some intense investigation we believe we have a work around. It turns out that Windows NT 4, 2000 and Windows XP must be using some space for the pagefile.sys file on the same partition that Poser is installed, to render large images. The pagefile.sys is the virtual memory or temp space for Windows. An approximate minimum would 10 MB. This amount might have to be increased for more complex scenes and animations. The maximum should be 10 MB or greater. To modify the Virtual Memory: Windows NT 4 = Right Click my computer. Click the performance tab. Click change. Click the drive Poser is installed on. Enter 10 in the Initial size field. Enter 500 or more, in the maximum size field. Click set. Click OK. Click OK. Click OK. Restart the System. Windows 2000 = Right click My computer. Select the Advanced tab. Click Performance option. Click Change. Select the drive Poser is installed on. Enter 10 in the Initial size field. Enter 500 or more, in the maximum size field. Click set. Click OK. Click OK. Click OK. Restart the System. Windows XP = Click Start. Right Click My Computer in the menu. Select Properties. Select the Advanced tab. Click Settings, next to Performance. Select the advanced tab. Click Change. Select the drive Poser is installed on. Click the Custom size button. Enter 10 in the Initial size field. Enter 500 or more, in the maximum size field. Click set. Click OK. Click OK. Click OK. Restart the System. Poser will now be able to render up to its maximum size of 4090 pixels x 4090 pixels @ any resolution"
ssgurl ( ) posted Sat, 09 August 2003 at 2:27 PM
you rule. no honestly, you rule. this totally fixed my issues. thank you, thank you, and thank you!
