Sat, Dec 28, 8:49 AM CST
Subject: Make your cave darker with negative lights
electroglyph ( ) posted Sun, 03 August 2003 at 10:48 PM ยท edited Fri, 27 December 2024 at 5:28 PM
This is an image I created of a cavern. the camera looks out from a passage into an open chamber where the roof has caved in. The chamber was created by using bryce rocks set negative and grouped with a positive bolean terrain to make the tunnels. There was no detail in the chamber till I used a blue light but it made the tunnel look unnaturally bright. I switched the light to negative and highlights showed up pink and the stlagtites had pink bright shadows. I guess a shadow from a negative light is bright. I turned the light red and the resulting darkness had a blue cast. I turned shadows off and got the image you see. Negative lights seem like a great solution to lighting problems I have and the render was only 45min.
Jaymonjay ( ) posted Mon, 04 August 2003 at 12:46 AM
Nice lighting! IMO this render would be way cooler without the stalagmites (stalactites? I can never remember which is which!). Anyway, the spikey things seem to clutter the scene. Not all caves have them, don'tcha know. :)
Kylara ( ) posted Mon, 04 August 2003 at 5:14 AM
Little tip for you Jaymonjay: In stalactites is the word "tits" and they're at the top of course ;)
TheBryster ( ) posted Mon, 04 August 2003 at 6:29 AM
Forum Moderator
Kylara: We used to learn this at school.....'tites come down' eg. Tights (pantyhose) come down...?
eelie ( ) posted Mon, 04 August 2003 at 6:30 AM
Or...stalactites hand "tight" to the ceiling; stalacmites are "mighty" and hold the ceiling up. Can't remember which teacher taught us that but it's stuck with me all my life. Interesting use of lights, electroglyph. I played once with caverns but didn't get good results. I'll have to try again and use this idea.
tjohn ( ) posted Mon, 04 August 2003 at 6:49 AM
The one I learned was stalaCtites have a "c" for "ceiling". StalaGmites have a "g" for "ground".
Flak ( ) posted Mon, 04 August 2003 at 7:18 AM
The one I learnt was... when the mites go up, the tights come down.
Digital WasteLanD
GROINGRINDER ( ) posted Mon, 04 August 2003 at 3:51 PM
Great cave shot and thanks for the lighting tip.
shadowdragonlord ( ) posted Mon, 04 August 2003 at 6:25 PM
Brycean caves totally rule, it's a passion of mine, good to see others working in the dark, too!
electroglyph ( ) posted Mon, 04 August 2003 at 6:51 PM
Second pass, Higher negative lights, shrank the stalactites. I put a tree and some dirt in the room where the ceiling fell in. More specularity on the walls, a little ambient color and reflectivity to the water. I need to blur theterrains used for the florite fountains more the edges of the pools look too sharp. I also might take the black back down(up?) a bit. I like a little blue twilight better.
SevenOfEleven ( ) posted Tue, 05 August 2003 at 4:48 PM
Looks great. Have heard of negative lights, was wondering when they can be useful.
