Thu, Nov 28, 6:59 PM CST
Subject: UNcompressing Poser files in ProPack?
Spit ( ) posted Tue, 05 August 2003 at 2:14 PM ยท edited Thu, 28 November 2024 at 3:55 PM
This is driving me nuts. I had to compress my character files in ProPack to save some space. But sometimes I need files uncompressed for use in various utilities. I have Winzip (and XP) and the ONLY way I've gotten it to work is to double-click a .crz, then double-click again when it shows up inside Winzip, then 'add' it to a zip (I have to make a new one). Then find the zip and 'extract'. I can only do it one file at a time..nothing else works. Renaming the extension from .crz to .zip doesn't work either. It takes forever. There's an UNcompress python script in Poser 5 but it doesn't work in Propack...and anyway it doesn't even let you paste a path. Thus brain dead and fairly useless. Anyone have any other method that works?
Little_Dragon ( ) posted Tue, 05 August 2003 at 2:46 PM
You can disable the compression feature in Poser's General Preferences, load a CRZ from the Library, and then resave it immediately to the Library as a CR2.
Since they have different file extensions, you won't be overwriting anything, and both files can coexist in the same folder. However, I'm not sure which will load by default. As long as they're identical, I suppose it doesn't matter.
Spit ( ) posted Tue, 05 August 2003 at 3:05 PM
Doh. That'll work. I don't have the compression feature turned on, been doing it with the python script on selected folders. Never though to re-save. LOL Thanks!
