Sun, Jan 26, 1:53 AM CST
Subject: Deleting frames
gddesign ( ) posted Wed, 06 August 2003 at 9:28 PM ยท edited Sun, 26 January 2025 at 1:42 AM
I have an anim of 30 frames, I want to create a variation of 15 frames total by deleting the first 15, but can't seem to do it. If I enter 015 in the LH frame counter box it doesn't delete them & I don't want to lose the existing 15-30 frames. Any clues? Also retiming the anim doesn't do it (In=ff15-30,Out=ff00-15).
chriscox ( ) posted Wed, 06 August 2003 at 9:40 PM
I've never used the Key frame editor until a couple of minutes ago but it seems that in the Key frame editor you can select frames 16-30 for all object and drag it over to frames 1-15 and the delete the excess frames. Chris Cox
Chris Cox
smiller1 ( ) posted Thu, 07 August 2003 at 5:47 AM
Whoa! 1- In the key frame editor darag down and select everything in frame 16 and click on key frame. 2- Do the same the frame 30. 3- select frames 1 - 15 and hit the delete key to clear everything out. 4- Now you can select everything for frames 16 - 30 and drag them to frames 1 - 15 and then delete frames 16 to 30.
chriscox ( ) posted Thu, 07 August 2003 at 9:46 AM
Opps, you're right I forgot that I had a Key frame at frame 16. Chris Cox
Chris Cox
gddesign ( ) posted Thu, 07 August 2003 at 7:27 PM
Thanks guys, that did the trick.
smiller1 ( ) posted Fri, 08 August 2003 at 2:52 AM
'2- Do the same the frame 30.' Despite the nonsense I wrote! :0) Glad to help.
