Mon, Jan 27, 12:23 PM CST
Renderosity Forums / Carrara
Welcome to the Carrara Forum
Carrara Free Stuff here.
Subject: More Comments needed please....
Grimpup ( ) posted Sun, 09 July 2000 at 7:46 PM · edited Sat, 10 August 2024 at 3:04 AM
Attached Link: http://www.geocities.com/grimpup_2000/swsh3.gif
Here we are at the second pass of the old sword and shield on the wall picture. In the empty space under the shield I am thinking of putting a table with a crown of helm on it. The wood pillars on either side do not look right to me and I am not sure what to do about it. So give me any feed back you can and just to make this fun I will not except any positive comments :) Thanks Grimpup
mclarsen ( ) posted Sun, 09 July 2000 at 8:19 PM
I'm not sure how you would avoid a positive comment, but point taken. You could try changing the mapping projection on the wood pillars. I, myself, would probably increase the resolution of the original shader or create a new one. You could also use some small bulb lights or such between each flame and the pillars since they appear not to throw any light on them for as close as they are.
AzChip ( ) posted Mon, 10 July 2000 at 10:35 AM
It is hard not to be positive about such an image, but I'll try.... I think the shader on the pillars is the culprit, here. It looks like it might be repeated too often in the vertical scale. The idea of small lights at the flame is good, too. I'd suggest using those as your only light source (unless you put candles or something on the table, too). I also think there's something wonky about the scale of the flame objects on the metal dishes. I can't figure out what's burning with that large a footprint. There. Nothing positive, OK?
Grimpup ( ) posted Mon, 10 July 2000 at 10:06 PM
The scene is lit with 5 lights. Each flame has a bulb light to it and I have a spotlight pointed at the shield. With just the bulbs the image is to dark around the shield. -Grimpup
AzChip ( ) posted Wed, 12 July 2000 at 10:09 AM
Hmmm.... Well, maybe there's too much ambient light? Or maybe the spot on the shield is too hot? I'm not sure, but I think I'd like to see a little more light dynamics....
