Sat, Feb 8, 10:59 PM CST
Subject: I need this column
camelot77 ( ) posted Wed, 06 August 2003 at 1:37 PM ยท edited Thu, 06 February 2025 at 12:36 PM
I dont like the column on the railing I am using, this column I am looking for I was using in Bryce but for some reason I cannot export it to an object format
Phate_ ( ) posted Wed, 06 August 2003 at 2:12 PM
you cant export objects from bryce (i dont think)
Spit ( ) posted Wed, 06 August 2003 at 2:56 PM
What version of Bryce? If it has any Bryce primitives, you can't export. Select the column and if an 'E' shows up on the strip beside it you're in luck.
geoegress ( ) posted Wed, 06 August 2003 at 5:31 PM
if you don't figure it out IM me- take about 2 minutes to make :)
dan whiteside ( ) posted Wed, 06 August 2003 at 7:18 PM
Sure looks like it will - select the column, hit the little "E" button and then in the Edit Mesh Dialog hit Control+D. Name it and select what export format you want from the pop-up and save. HTH; Dan
brycetech ( ) posted Wed, 06 August 2003 at 9:30 PM
Attached Link: Export Tutorial
here is the whole story on exporting from bryce: http://www.brycetech.com/tutor/bryce/export.html it will tell you if you can or if you can't export the model. luck BT
geoegress ( ) posted Wed, 06 August 2003 at 10:10 PM
10 minutes- I'm not very good at it yet :)
Bladesmith ( ) posted Fri, 08 August 2003 at 2:06 AM
Attached Link: http://www.isauras.com/
I am almost certian that Isaura made that.
