Tue, Nov 26, 6:30 AM CST
Poser - OFFICIAL F.A.Q (Last Updated: 2024 Nov 26 6:11 am)
Subject: bum files in poser 5
camelot77 ( ) posted Fri, 08 August 2003 at 10:40 PM ยท edited Thu, 15 August 2024 at 6:32 AM
I have a skin texture that keeps asking me for a bum file, how do I get this texture to load?
wdupre ( ) posted Fri, 08 August 2003 at 11:22 PM
is there a propack version of the Mat file? if so use that, if not, it stll should load(after asking about every infrence to the texture in the mat file) if you have the latest update. but you might have to go into the mat file and change every instance of .bum to .jpg
camelot77 ( ) posted Fri, 08 August 2003 at 11:28 PM
thanks I will try that
yggdrasil ( ) posted Sat, 09 August 2003 at 10:04 AM
Attached Link: http://www.renderosity.com/freestuff.ez?Form.Contrib=hogwarden
There's a utility called CorrectReference in freestuff that will change references in MAT (or other library) files to non-existent bum files to point to jpg, tif or bmp if one of the same name exists. It also fixed incorrect directory names in the texture references which can make P5 extremely slow at opening figures/mats/props etc. and can sometimes cause rendering to freeze. -- Mark
Mark
