Fri, Jan 24, 5:09 PM CST
Forum Moderators: Staff
Subject: Something interesting in the Wavefront OBJ specs...
_dodger ( ) posted Mon, 11 August 2003 at 2:14 AM · edited Fri, 24 January 2025 at 5:06 PM
Attached Link: Wavefront OBJect File Format Specs
I was reading through te Wavefront OBJect file format specifications and came across something VEEEEERY interesting... (emphasis added) *Faces and surfaces can be assigned into named groups with the "g" keyword. This is used to create convenient sub-objects to make it easier to edit and animate 3D models. **Faces can belong to more than one group.*** What implications could this have on Poser model building? When a poly can exist smultaneously in two different groups? There is some other interesting stuff in there, that might crash poser or might be properly read by poser, like 'cstype' and 'surf' -- I don't know if any experimentation has been done with these.
williamsheil ( ) posted Mon, 11 August 2003 at 6:38 AM
  • Faces can belong to more than one group. * Actually, if you think about this is already a feature embedded and probably frequently used in Poser's Group Editor. Here it has always been possible and practical to define multiple groups for morphing, texturing, bone cutting etc. and to rely on that fact that when you create a new group for a specific purpose and won't effect the existing groups through some implicit mutual exclusivity. As far as the other object format parameters are concerned, I've always assumed (my bad) that while the file format is quite "featured", Poser probably only supports the subset that describes polygon meshes (including, of course ignoring vertex normals). Certainly I would be very surprised if there is actually code to handle splines and patches and such like nestling in the Poser core, unnoticed and unused for all the years. And, after all, it's not just a matter of being able to interpret the file format but really depends on whether the functionality is embedded in program to actually make use of the data. One thing I've never checked is whether the P5 dynamic hair (or guide strands) actually export in .obj format, and if so how they are defined. Bill
_dodger ( ) posted Mon, 11 August 2003 at 6:43 AM
Actually, if you think about this is already a feature embedded and probably frequently used in Poser's Group Editor. Hrm, perhaps. What I'm wondering is now exactly one declares this. Will the 'g' declaration accept more than one argument? Because simply defining the same face more than once would be declaring a new face (poly), according to the spec, even if it shared all the same vertices.
williamsheil ( ) posted Mon, 11 August 2003 at 7:15 AM
I had to check this, but according to my (old) copy of the spec, this is exactly the case: ******************************************************* All grouping statements are state-setting. This means that once a group statement is set, it alpplies (sic) to all elements that follow until the next group statement. This portion of a sample file shows a single element which belongs to three groups. The smoothing group is turned off. g square thing all s off f 1 2 3 4 ... Syntax g group_name1 group_name2 . . . Polygonal and free-form geometry statement. Specifies the group name for the elements that follow it. You can have multiple group names. If there are multiple groups on one line, the data that follows belong to all groups. Group information is optional. group_name is the name for the group. Letters, numbers, and combinations of letters and numbers are accepted for group names. The default group name is default. ******************************************************* Bill
_dodger ( ) posted Mon, 11 August 2003 at 7:39 AM
So.. I have to expiriment with what happens when a poly belongs to more than one body part This might be yet another way to acheive the whole skirt and bat wing thing. Maybe.
williamsheil ( ) posted Mon, 11 August 2003 at 8:44 AM
That's an interesting thought, and well worth looking at, but my first thought is that I believe that Poser splits the mesh polygons and vertices into seperate body part meshes (with possible vertex duplication) according to the body part specific groups. Part of the reason for this specific partitioning (if it exists) may well be precisely to avoid any conflicts in poly membership to multiple body part groups. In this case, I would expect that either: Poser just takes the first group label and ignores any other labels, at least for this part of the processing, therefore it's "first come first serve" scenario and the poly only becomes part of one body part. or Poser duplicates the face in each of the new body part objects that it encounters an association with. Still, it would be interesting to see what results you come up with. Bill
EnglishBob ( ) posted Tue, 12 August 2003 at 7:26 AM
It's my belief that the OBJ spec is just a source from which Poser has "borrowed" a convenient mesh format. As far as I know, only v, vt, g, and f are used, along with usemtl when importing. However, note the use of the terms "belief" and "as far as I know". Beliefs like that can sometimes be overturned. :)
EnglishBob ( ) posted Tue, 12 August 2003 at 7:36 AM
I mean, of course "only v, vt, g, usemtl and f are used, along with mtllib when importing" Put brain in gear, THEN engage mouth... :)
DraX ( ) posted Thu, 21 August 2003 at 2:42 PM
Poser does infact, in my experience ingore secondary, tertiary, and so on group assignment for a polygon set. As a matter of fact, let's say you label a group as followed: g head lips If you did that for let's say, the lips in the P4Male, and saved a new cr2 pointing to the new geometry, you would notice that the head itself is still intact, and should (I believe) handle morphs just fine. However, you will also notice when clicking on the head and opening the group tool that a subgroup called lips exists.
Kevin ( ) posted Wed, 03 September 2003 at 12:38 AM
Way back when Zygote released a pair of models with the full obj hierarchy in place from Wavefront. This was a mistake on their part, as the final step was supposed to be removal the overlapping groups, many of which are not available in poser. IIRC, I'm the one who pointed out to them the wacky OBJ files. They were loadable in poser, but acted sort of squirrelly. They also had VAST rsr files. They fixed them and shipped out ones with the multiple groups removed. I have the ones with all the groups around somewhere, but they are only of academic interest. The use of multiple groups is one of the tricks that zygote/DAZ uses to make their models, particularly morphs. This is also why you will probably not get DAZ to ever send you their internal use OBJ files.
Staale ( ) posted Sun, 14 September 2003 at 11:43 AM
V3 uses a single vertex for group borders, this vertex is grouped to both body parts. My PLH: Morph injection builder can handle 10 groups and 10 materials for each vertex.
kuroyume0161 ( ) posted Mon, 26 July 2004 at 5:54 PM
Sorry to be late here, but from my experience, Poser doesn't particularly ignore any of the group assignments in an OBJ file. What it does do is correlate actor/prop declaratory names (geomHandlerGeom 13 head) to a matching OBJ group. I've seen this (literally): g owl wings g head owl and, dangnabit, Poser finds 'wings' and 'head', order-insensitively, to match the body part groups. Beware what you assume... Kuroyume
 -- Bjarne Stroustrup
ynsaen ( ) posted Tue, 27 July 2004 at 6:23 PM
digs into her bag of tricks more deeply, and notes that while Poser does support the entire spec, it doesn't have active handles for everything listed. Poser 5 does import Rhino exported nurb meshes -- ie, with all them fancy splines and stuff. How much it uses I don't know. I'se only a fifth grader poser hacker...
