Sat, Feb 8, 4:21 PM CST
Subject: How to make Bump Maps
HAE_Inc ( ) posted Mon, 11 August 2003 at 11:16 AM ยท edited Sat, 08 February 2025 at 12:49 PM
Hi,
Well I was wondering just how do I make a bump map for like a tile floor. When I posted my "first poser pic" last week someone who kindly reviewed said that I should make a bump for my floor and I must say i am at a loss as to how to do that, I know it has something to do with greyscale but I'm really up the creek on this one.
Thanks
compiler ( ) posted Mon, 11 August 2003 at 12:20 PM
OK, I'm assuming you're using Poser 4. You need a 2D program (photoshop, Paint Shop Pro, etc...). Make a white square and put a black grid on it (better use 2 layers). If you want your tiles not to be too sharp, apply a small amount of blur to the black grid. Save as JPEG or TIF. Use this map as a bump map (Poser 4 will ask you if you want to convert it to bump map, say yes). This will give the look of a tiled floor. Re open the original black on white grid (the Photoshop or Paint Shop pro one) and paint the white squares with something you like (or better still, paint the whole white layer, then put back the black grid on it). Save as JPEG. Use this one for the texture of your ground. If you're using Poser 5, it's even more simple : open the material editor and chose "tile" for your texture. Any image you'll load in will repear itself over the ground (provided the image is not too big for the ground, but that can be fixed with the "scale" parameter).
compiler ( ) posted Mon, 11 August 2003 at 12:21 PM
Oh, and thank you for the color change in your posts...
