Mon, Feb 10, 4:07 AM CST
Subject: Utilities for opening self-extracting archives?
Phantast ( ) posted Tue, 12 August 2003 at 5:19 AM · edited Wed, 05 February 2025 at 1:53 AM
Does anyone know of a program for opening a self-extracting archive as if it were a zip file? I'm really getting rather sick of the Daz .exe files, which install every file in a package even if I don't want some of them, and always installs them in places I don't want them installed. After every installation I have to tidy up, move things into the folders I want them in and delete the excess folders that the installer has rudely created. I can do without this.
KarenJ ( ) posted Tue, 12 August 2003 at 5:48 AM
You know when the installer searches for your copy of P4/5 and says "Files will be installed in the following directory"? Just hit the browse button and get everything to install to a Temp folder in your My Documents instead. All the paths will be intact so you can rename to your own conventions and then just bodily move the Runtime folder into P4/P5. That's what I do... HTH
"you are terrifying
and strange and beautiful
something not everyone knows how to love." - Warsan Shire
TrekkieGrrrl ( ) posted Tue, 12 August 2003 at 6:35 AM
Actually, just hit "cancel" when the installer starts searching and you can manually input wherever you want it to install to. If you then choose a temp folder for instance on your desktop, you can easily move it afterwards.
Jackson ( ) posted Tue, 12 August 2003 at 10:09 AM
Winzip will open self-extracting files created with Winzip (and a few others, I think). Just right-click on the exe and select, "Open with Winzip." This won't work with DAZ files though; they must use a different compression method or something.
Phantast ( ) posted Tue, 12 August 2003 at 10:13 AM
Thanks all! Using a temp directory is an excellent idea. I suspect that Daz files use a cab file within an installer program. I'm sure it must be possible to get at it somehow, if not with Winzip.
praxis22 ( ) posted Tue, 12 August 2003 at 12:30 PM
try winrar, that will open .cab files
Phantast ( ) posted Wed, 13 August 2003 at 5:00 AM
Just tried out the temp file idea and it works a treat. The texture for the item in question was buried in a layer of unnecessary subdirectories about five levels deep! Some of us have to find these files, you know ...
