Fri, Jan 24, 8:26 AM CST
Poser - OFFICIAL F.A.Q (Last Updated: 2025 Jan 23 9:03 pm)
Subject: Question re: The V3 MalePak
ecb ( ) posted Thu, 14 August 2003 at 6:48 PM ยท edited Thu, 09 January 2025 at 10:40 AM
I'm still a novice at this and am probably missing something obvious but, whenever I setup the V3 for male features one of two things happens, either it doesn't work as a body morph or I lose the morph when I make some modifications. What am I missing? Is it because it must always be the V3.srl model or what?
queri ( ) posted Fri, 15 August 2003 at 12:11 AM
You did all the patches, right? I think it has to be V31a, but I'm not sure. It does have to be the patched V3 model. Not the blank one. And you need the correctly patched Male morph set too. But if you bought it recently you probably have that. Having said that-- I occassionally lose morphs myself and just reapply them. On Poser 5 and I never know what's a bug or a feature.:) Emily
dcasey0284 ( ) posted Fri, 15 August 2003 at 12:48 AM
I'm new at the V3 Male Morphs myself. Do the V3 (female) body and head morphs need to be 'injected' for the 'male' to work right? It takes so long to load these things sometimes, any shortcut is a real time-saver. Also...what poses can I use with the V3 male? Michael poses? I figure just about the time I figure some of this out the new Mike 3 will be out and I'll have to start all over. :-) Doc
queri ( ) posted Fri, 15 August 2003 at 6:03 AM
I inject some of them-- anything that is muscular. You don't need the breast morphs -- maybe the flat chest one. Use any pose that appeal to you-- you'll get the warning that some of these objects don't apply, yeah yeah, sure sure, click that off and see what happens. V3 poses might be a llittle femmy in the hands, but almost any pose needs some tinkering. Emily I'm not at all sure I'm doing it right, myself.
RHaseltine ( ) posted Fri, 15 August 2003 at 8:58 AM
The male pack bodies and faces have their own injectors - you can just use the standard unladen V3 figure. Mike (1 or 2) poses may give odd reults from the two-part neck of the earlier Mil. figures, but should be usable with tweaking: however, the V3M joints are still V3's so V3 poses will be best - you'll just need to adjust if he has, say, his hand on his hips, but that's true of any morphed figure.
ecb ( ) posted Fri, 15 August 2003 at 4:02 PM
Thanks people, I'll give it a try...
dcasey0284 ( ) posted Fri, 15 August 2003 at 8:23 PM
Thanks...I tried some of the M1-2 poses and they seem to work ok...so far. Mahalo!
