Wed, Feb 5, 1:26 AM CST
Subject: sarah spriteling problem
wotdoin ( ) posted Fri, 15 August 2003 at 1:06 PM ยท edited Fri, 31 January 2025 at 10:53 PM
Help! I have loaded V3 applied the prop deformer file, then went to the pose library and tried to just load a MOR for the ears (I am starting small since I have no idea what I am doing) Well the ear mor didn't work so I re read the directions and I am supposed to apply the INJ file for V3 first. I applied MOR face 0 V3 and nothing happened then I tried the Mor face dfit pose and still nothing happened. Am I doing something wrong. Do I need to select the head or body first? Oh and I did get the update from DAZ the other day which is suppose to update the file. thanks, Debbie
redon634 ( ) posted Fri, 15 August 2003 at 1:25 PM
I did this the first time, too. You have to go into the props library and load the magnets first. Then apply the mors
Momcat ( ) posted Fri, 15 August 2003 at 2:03 PM
The MOR is the morph adjusting pose, the INJ is a seperate pose that injects the necessary parameter dials, then use the MOR poses. The MOR face 0 will restore the default V3 face, the other MORs apply the SS faces.
redon634 ( ) posted Fri, 15 August 2003 at 2:30 PM
Whoops - I see you'd already loaded the magnets. Hope momcat's suggestions helped you.
wotdoin ( ) posted Fri, 15 August 2003 at 2:51 PM
I did read that in the help file that came with the package but I don't know where the inj file is? What is the name of it or do I just load the original V3 inj? Thanks for all the sugestions. Debbie
igohigh ( ) posted Fri, 15 August 2003 at 3:04 PM
Spit ( ) posted Fri, 15 August 2003 at 3:05 PM
Load V3. Be sure Body is selected. Then go to the Props library and double-click the "Sarah Spriteling DFM". I've changed my folder names but if you didn't rename the folder I think it will be on the top of the list in Props. It has only one file in it. (These are the magnets) Then go to the Poses library and find your Sarah Spriteling folder. It should be the first one in the folder: !!!INJ Sara Spriteling MOR and double-click it. This will load up the Face morphs. Now you should be ready to play.
wotdoin ( ) posted Fri, 15 August 2003 at 3:39 PM
That worked great thank you, kinda confusing when you don't know what you are doing. Thanks!
