Fri, Sep 20, 2:37 AM CDT
Poser - OFFICIAL F.A.Q (Last Updated: 2024 Sep 19 11:01 pm)
Subject: Lashes on P4....
DigitalDreamsDS ( ) posted Fri, 15 August 2003 at 4:44 PM ยท edited Sat, 27 July 2024 at 4:59 AM
How do I make the plastic lashes not show when rendered... they don't look like what normal lashes should.. Thank you.
Tashar59 ( ) posted Fri, 15 August 2003 at 5:09 PM
You need a trans map loaded, and set all the lash material colors black. Not your base color if you want different color lashes. Try the settings in the pick. Remember the trans lash can be on a different map, like head on v1/2, or has its own map. I just threw the possette in for the pics.
Tashar59 ( ) posted Fri, 15 August 2003 at 5:12 PM
PS. The Reflective Color should be Black too. Couldn't edit after posting.
DigitalDreamsDS ( ) posted Fri, 15 August 2003 at 5:25 PM
Thank You... Where would I get a trans map???
Tashar59 ( ) posted Fri, 15 August 2003 at 6:27 PM
On possette, it is on the body tex, V1/2 on head tex, on it's own in other packages. Might want to try opening a tex folder and look through the files. It will give you a better ideal where every thing is and named.
