Poser - OFFICIAL F.A.Q (Last Updated: 2025 Jan 10 1:16 pm)
Nope I didn't use the re-map (don't have it) wouldn't be that hard to switch though. All the Beta tester really needs to do is make sure it installs correctly, and the decoding process works. I can't remember if there was a update to the vicky .obj or not, or if there was did I use it? Mike had one that would mess with the moving process. I know the morphs transfer just fine after the install (used several for the image) And yes definatly a freebie.
