Wed, Nov 20, 9:05 AM CST
Vue F.A.Q (Last Updated: 2024 Oct 26 8:50 am)
Subject: Render one after the other?
Tiny ( ) posted Wed, 27 August 2003 at 5:27 PM ยท edited Thu, 18 July 2024 at 2:04 AM
I have 2 animated animals from Poser. Is it possible to set up one animation after the other in Vue?
For example:
  1. Animal 1 imported from Poser.
  2. It is set up for rendering and preview render made. 15 frames.
  3. Animal 2 is imported.
  4. It is setup for rendering and "lined up" after animal 1's render frames. +15 frames.
    All together 30 frames.
If this is possible I could have a bunch rendered at night while I'm sleeping. :o)
If it is possible, then how? I have tried for hours to make it work.
haegerst ( ) posted Thu, 28 August 2003 at 3:15 AM
Yeah - It IS possible... Just make two scenes out of the animation - save the first 15 frames lets say as "animation1.vue" and the second as "animation2.vue". Then use the Vue batch renderer (is included in your standard install) to first render the animation 1 and then animation 2... While Vues rendering, you go to sleep... :-) OK, I must confess I only used it for stills, but Im sure it also works for animations...
Vue content creator
www.renderarmy.com
Tiny ( ) posted Thu, 28 August 2003 at 8:25 AM
Yes it works for stills! Great. But I can't figure out how to get it to render the whole animation. Anyone?
Tiny ( ) posted Thu, 28 August 2003 at 3:38 PM
I just found when doing a search that it will not render animations. Hope that is included in Vue 5. :o)
