Sun, Feb 2, 10:06 PM CST
Poser - OFFICIAL F.A.Q (Last Updated: 2025 Feb 02 7:25 pm)
Subject: Weird shoulder....
Zhann ( ) posted Mon, 01 September 2003 at 4:56 AM ยท edited Sun, 02 February 2025 at 7:15 PM
Hi there, I've just started with Poser so I'm learning....I have a wip in Bryce that needs a nude. I'm getting used to using the dials to position the limbs of the figure, but I've noticed a weird problem, see image, how do I fix the shoulder so it's normal? And I notice when importing into Bryce some body parts seem odd, any ideas....? I really don't want to fix this in post if I can avoid it...any help appreciated, thanks, Zhann
Bryce Forum Coordinator....
compiler ( ) posted Mon, 01 September 2003 at 7:48 AM
No ideas on Bryce importing. As for the shoulder, it could be that you made the arm go forward by using only the shoulder dial. To achieve a more natural look, you should try to allocate your whole movement between the several locations involved. Here, for a total move of 90 front, I'd give a 20 to the collar and the rest to the shoulder. Make sure also that you keep the other dials (twist and side-side) as low as possible for the effect you seek. The less you push the dials, the less the geometry deforms.
