Are you sure you also had exactly these 2 lights also placed in Vue? Can you check the helmet material in vue? Normally you should be able to "open" the figure if it has a "+" in front of its name, when you click on that... Materials aside from Textures are not always 100% what they are in Poser when you import them, so check that...
Vue content creator
www.renderarmy.com
Hmmmmmmm, one major problem with the glass material of the helmet in the Vue image is that it has no refraction index. Glass has a refraction index of between 1.5 to 1.8. The easiest way to rectify the problem you have is replace the Poser imported texture with a Vue glass material. Hope that helps, Cheers
Twitter: Follow @the3dscene
No you didn't say Poser couldn't do good glass, you said Vue's is better. Poser 5 has every thing Vue has to create glass plus it has refraction (Mentioned by Cheers above) and it has translucence two key properties of glass. So with enough playing with it, you can get better glass then Vue can do. :) Of course you will still be looking at it under Poser's lights that are not as good as Vue's. :D
