Wed, Nov 27, 6:56 PM CST
Subject: Newbee Question....
Hekate ( ) posted Fri, 21 July 2000 at 9:50 AM · edited Tue, 19 November 2024 at 11:23 PM
I only worked with Poser most Time, but now i Try to use Bryce. My Problem is, i cant export any Object from Bryce. The Option in the Menue is disabled. This cant be normal?!
Spanfarkle ( ) posted Fri, 21 July 2000 at 10:07 AM
I don't think it is possible to export objects you create in Bryce, only terrain's.
Caligula ( ) posted Fri, 21 July 2000 at 12:37 PM
Primitves that are created in Bryce can not be exported from Bryce. However, if you use the primatives that are in the "imported objects" library in Bryce to make your shapes, you can export the final product. Group them together, click on the E and then type CTRL D It will pop up an export window. Sarah
Hekate ( ) posted Fri, 21 July 2000 at 8:27 PM
I only want to work with imported Objects and then export them for Poser. So your Help was very useful. Thanx.
Caligula ( ) posted Sat, 22 July 2000 at 2:21 AM
Check out the imported objects that come with Bryce. Click on the triangle to the right of the word "Create." That will take you to the OBP preset library. Click on the "Imported Objects" In there you will find a sphere, a cube, a pyramid and many more interesting shapes.
