Sat, Jan 25, 1:21 PM CST
Forum Moderators: Staff
Poser Python Scripting F.A.Q (Last Updated: 2024 Dec 02 3:16 pm)
Subject: Once you tell a computer what you want it to do, it's very difficult to stop it
smiller1 ( ) posted Thu, 04 September 2003 at 3:36 PM · edited Fri, 10 January 2025 at 9:06 PM
I wanted more control over the Poser 5 renderer so I've written a script that renders every tenth frame of a scene and then goes back to the start and renders all the missing frames. If I have to abort the process and start again, my script checks to see the rendered file exists before rendering and skips it if it exists. Trouble is, the only way I can stop the process is using cntl-alt-delete and killing Poser from the task menu. What I'd like to do is have a button which is available to click while my main script is running. When I click it, it can set a flag of some sort which my main script can check between renders. If it is set, then the main script can quit processing till another day. Is this possible within the poser-python environment?
ockham ( ) posted Fri, 05 September 2003 at 10:09 AM
The best way to do it is with Tkinter, which has a neat "put-self-in-background" action. The attached file will do pretty much what you want, I think.... It has start and cancel buttons, but it seems to start immediately upon activation instead of when you hit the start button. The main point, though, is what happens when you hit Cancel: it stops dead. Look at the Update action to find the key for "self-in-background".
My python page
My ShareCG freebies
smiller1 ( ) posted Fri, 05 September 2003 at 1:34 PM
Thank you Ockham- I've downloaded it and I hope to get time to look at this over the weekend.
smiller1 ( ) posted Fri, 05 September 2003 at 2:05 PM
Looked at it already. It terrific! Thank you, thank you, thank you. Strangely, when I saved it, the line... if NextFrame < 0: return # Handling the cancel got corrupted which was actually quite good because it made me figure out what the program was doing to fix it. Now all I have to do is incorporate my code into your skeleton, which looks very easy to do. Did I say thank you? Thank you.
ockham ( ) posted Fri, 05 September 2003 at 3:22 PM
"Strangely, when I saved it, the line... got corrupted which was actually quite good because it made me figure out what the program was doing to fix it." That's why I call this place Serenderosipity!
My python page
My ShareCG freebies
smiller1 ( ) posted Sat, 06 September 2003 at 4:39 PM
:0) Well I made my changes and it worked fine for my simple test scene, but when I used it on a bigger 'real' scene, the renders only came out a quarter done. Any ideas why this would happen?
smiller1 ( ) posted Sun, 07 September 2003 at 4:52 AM
Looks like a memory problem, I reduced the size of the render box and it worked fine last night.
ockham ( ) posted Sun, 07 September 2003 at 9:34 AM
Hmm. I wonder if it could have something to do with the timing of the Update. Does the smaller render take less than 250 msec? (1/4 sec)
My python page
My ShareCG freebies
smiller1 ( ) posted Mon, 08 September 2003 at 11:10 AM
That was my first thought, till I saw the timer was set to 250ms. Lowering the bucket size (not render box! had my own memory problem there.) made the render time slightly longer so I reckon it's a memory thing.
