heyas; um... as you all (probably) know, morph manager doesn't do full body morphs (which is minor). BUT i have recently just found out that when you move morphs with it, it does NOT move the slave channel lines that you need for FBMs and JCMs. so if you use morph manager and these don't work, that's why. (if you DO use morph manager, and they work, tell me what version you have! :) ) thanks for the work, director! :)
Attached Link: http://www.3Ddude.com
Just posted the first JCM CR2 Files for characters. In case you arent aware Joint Controlled Morphs are morph targets that are triggered by joint motion, thus giving a simple muscle like movement. It removes the stiff poser look with a slightly more fluid one. These JCM figures implement morphs in the arms, legs, and torso. Included with the CR2 files is a document with some tips that you can use in addition to Nerds Tutorial. Check it out. Learn from it. Use Morph Manager to place the morphs in your own figures. Have fun and remember to send me a copy of any new developments you come up with.
