Sat, Jan 11, 11:10 AM CST
Subject: Grouping tool...aarghh!
mon1alpha ( ) posted Mon, 08 September 2003 at 6:23 AM ยท edited Sat, 27 July 2024 at 7:00 AM
Hiya This is probably in the bleedin' obvious category but I seem to be having brain problems :) When I select parts of the mesh to assign textures to, I quite often select the wrong flippin' facets. Is there a way to de-select part of a group rather than deleting the new group and starting again? Thanks for your time Mon
adp001 ( ) posted Mon, 08 September 2003 at 7:37 AM
Press CTRL + left mousebutton to deselect facets.
mon1alpha ( ) posted Mon, 08 September 2003 at 8:31 AM
Bless you :) Thanks a lot, domo arrigato gozaimasu. Mon
sturkwurk ( ) posted Mon, 08 September 2003 at 10:33 AM
Or... use the group tool to select the facets you dont want, then do an inverse. or... dont forget to use the materials already included to help speed up the process... for example if you're working on a fingertip, "nails" are probably already assigned a material.
I came, I rendered, I'm still broke.
mon1alpha ( ) posted Tue, 09 September 2003 at 3:56 AM
Useful tips...is there no end to Poser? :) At first..a quick render and I was happy...now 'Oooh, I think those handlebars would look better with a reflection map of dark chrome..etc'
