Wed, Nov 27, 8:15 AM CST
Subject: Need help!
Black_Star ( ) posted Thu, 11 September 2003 at 8:23 AM ยท edited Sat, 23 November 2024 at 2:34 PM
Hy there!I don't know if this is the right place to post this , but I need help! I export body parts from Poser to edit them on an external 3D editor.The purpose is to create morps.I export what I want , I save it and the next window , in wich you can choose that you want to export the part as a morph only , does not appears.And this is bad..Is bad because all my morps deviates on one or all axes once imported in Poser. I've been looking on all the settings I can find , but I canot activate that window. My question is : what to do?What to do for my morphs to work correct? For more informations go to this page : http://www.3dtoday.com/Tutorials/2000/sept/posermorph/default.asp You will see some pictures in this page describing some of the Poser windows.The menu that dont' appears at me is the one from the picture 2 , from top to bottom. That one in wich you can choose to export the body part as a morph target only. Thanks for reading this! Best regards!
geep ( ) posted Thu, 11 September 2003 at 9:18 AM
Black_Star,
You will only see "that window" (picture 2) ...
AFTER you specify a "filename" and click "OK."
Ok? ;=]
cheers,
dr geep
cheers,
dr geep ... :o]
edited 10/5/2019
Black_Star ( ) posted Thu, 11 September 2003 at 10:22 AM
Hy there again! Well , that's the problem!I specify the filename and click OK.Poser saves the .obj but the window doesn't appears.. I know when it must to appear but does not appear at all! I could have disabled it from somwhere?Maybe my .exe is not the good one?Could be some old versions of Poser 4 that do not have that option implemented? Thanks for the reply , altough it has not solved my problem! Best regards!
geep ( ) posted Thu, 11 September 2003 at 11:10 AM
Black_Star, Check which version of Poser you have. Latest version of P4 is 4.0.3.127 Suggest you reinstall Poser if you still have this problem. ... or go to Curious Labs website and d/l patch if necessary. cheers, dr geep ;=]
cheers,
dr geep ... :o]
edited 10/5/2019
Spit ( ) posted Thu, 11 September 2003 at 6:34 PM
Are you exporting to wavefront obj format? or something else.
