Sat, Jan 11, 12:42 PM CST
Subject: Female warrior : - Trial loft of Kalypso's boots
bergerac ( ) posted Tue, 25 July 2000 at 6:47 AM ยท edited Sat, 11 January 2025 at 10:04 AM
To all those who showed interest in my sketches, just to let you know I'm making progress :) This is just the first trial loft of the boots (and a quick render in Rhino, sans maps 'n stuff). Still a lot of work to be done, especially on the feet, but coming on nicely. The final model should have a lot more detail (and will fit properly :) I'll work on this again tonight. Berge
LoboUK ( ) posted Tue, 25 July 2000 at 6:54 AM
Looks pretty damn' good so far Paul
robert.sharkey ( ) posted Tue, 25 July 2000 at 5:52 PM
Berge, this looks like you will come really close to your sketch. Have you used "project curve on object"-command ? SHARKEY
bergerac ( ) posted Wed, 26 July 2000 at 3:58 AM
Sharkey, no, that command only works on objects made from NURBS surfaces (That's why everyone is so keen for a mesh-to-nurbs command :). I had to project the points of my cross section curves and snap them to the mesh and then adjust them. The problem really is that, to get horizontal creases, one has to work with vertical crosses, which means you sort of run out of cross sections when you get to the feet. But I think I solved that problem this morning in the bath :) Berge
