Poser - OFFICIAL F.A.Q (Last Updated: 2025 Jan 27 5:49 pm)
Software: Daz Studio 4.15, Photoshop CC, Zbrush 2022, Blender 3.3, Silo 2.3, Filter Forge 4. Marvelous Designer 7
Hardware: self built Intel Core i7 8086K, 64GB RAM, RTX 3090 .
Filename-truncating syndrome? I have 318 folders in the pose library not including the ones for M3 (who I had to completely remove because he was crashing Poser). I starting doing housecleaning this week myself hoping to get M3 to work, but emptying my runtime didn't do the trick. Anyhoo, I was just wondering about Poser's limit's. Thanks for the scoop. bB
You can create a folder outside of the libraries, i.e. in your textures folder or anywhere on your computer and put little used pose folders into it. I call mine Pose Archive. The PD30 free explorer can then be used to view them. It is just a matter of copying and pasting them back into the pose folder when wanted. pboost is good if you can get the hang of it.
er, 255 per library type, ie, 255 pose folder, 255 figure folders, etc. Pboooost is the answer. You have two capabilities with that. You can consolidate some of your library items into one folder and ditch the empty one, or you can set up different banks (depending on how you set up your OS). You can go to Pose library for example and switch between a mat bank and a pose bank. P5 has the ability to link to your P4 library if you don't want to reinstall everyting. P5 also has sub directories that P4 does not do without Pbooost. Another observation is that DAZ and some others install two folders, one for P4 one for PPP. Delet P4 if you have PPP and vise versa. Backup before deleting.
Well, I finally did it. I finally killed my P4. Yup, as the Pose library folders were multiplying, the number of characters of the folder names being displayed was getting shorter and shorter, and now I finally cannot switch to the folders at the end of the list. Obviously, Poser has a maximum number of directories in each Library that it can deal with. Does anyone know of a workaround? Take care; Chas
