Sun, Feb 9, 3:32 AM CST
Subject: Stephanie's Pubic Hair
Odiemance ( ) posted Mon, 22 September 2003 at 7:06 PM ยท edited Mon, 03 February 2025 at 1:06 AM
This is an export of Stephanie, rendered in Bryce 5. Can you notice how the bump on her hip just does'nt look natural? That is her pubic hair. I've had the same problem exporting Mike 2, but he has a morph to delete this. I looked for one in Stephanie, and even transfered Mike's, but nothing will get rid of it. Anybody know how to fix this? I have a copy of Carrera 2, but it is'nt installed, and I hav'nt had the time to pick it up very much.
Dash ( ) posted Mon, 22 September 2003 at 8:16 PM
Set the pubichair material trasparent, the same way you would get rid of the eyeballs on bryce that should get rid of it or you could select the pubic hair area in your modeler and delete it. Hope this helps.
Badco ( ) posted Mon, 22 September 2003 at 9:01 PM
In Bryce 5 you can hold down ctrl and click on the mound, select it from the list, (its called hip 1_1 I believe), and then hit delete.
DarkMatter_ ( ) posted Tue, 23 September 2003 at 2:51 PM
Hey you need to use a trans map to make the pubic hair area work.
Odiemance ( ) posted Tue, 23 September 2003 at 8:05 PM
Hey you guys are great, I'm definately saving this thread to my hard drive for future referance! I'll be trying badco's techique as soon as I get home. Now do you boys mean I set the transparency from within bryce!? I've been thinking of this...How do you suggest this be done? I have added a body texture of hers, to her pubic part, as a node, this did'nt seem to work? Of coarse it did'nt justle any memories of how I used that techquenique, similarly, with P5 and M2, so mabey I'm doing it wrong? I just do'nt remember this approach transfering to bryce. As far as breaking Carrera out for this is concerned, I'll be needing someone to hold my hand through it, just as well as asking someone to do it for me.
Badco ( ) posted Wed, 24 September 2003 at 7:09 AM
There is a decent tutorial on transmaps from Poser to Bryce here: http://www.shar3d.com/ under tutorials/KattMan.
