Mon, Feb 3, 8:19 PM CST
Subject: New Daz Freebie
pizazz ( ) posted Fri, 26 September 2003 at 5:31 AM · edited Mon, 03 February 2025 at 8:17 PM
M3 shorts, do they work for anybody? Mine show they are loaded, but are completely invisible... Also the character library is messed up = shows 3 rsrs labeled M3 shorts and 3 rsrs with the shrugging guy labeled _M3 Shorts. I tried both, but neither works.
randym77 ( ) posted Fri, 26 September 2003 at 6:01 AM
Same here. Must be a bad upload.
miken999 ( ) posted Fri, 26 September 2003 at 6:58 AM
I have the same problem ... The short name appears on the scene, but no short visible.
blue2000 ( ) posted Fri, 26 September 2003 at 9:25 AM
I got the same problem thought it was just me.
MarianneR ( ) posted Fri, 26 September 2003 at 9:31 AM
It's the same problem with the mac version - three shrugging guys and three normal pictures. None of them work. But the real problem is that they forgot to put the groups into the obj, that's why the shorts are invisible. It can be fixed with UVMapper though if you don't want to wait for DAZ to upload a working version. Select the materials in the list to the right one by one, and assign them to the correct group (which you'll have to type in the first time), save the obj and make the cr2's point to your new obj (only necessary if you chose a new name). Just to be safe, work on a copy of the file.
nickedshield ( ) posted Fri, 26 September 2003 at 11:27 AM
Thank you for the workaround. I followed your directions with no problems. Now to delete the shrugging guys.
MarianneR ( ) posted Fri, 26 September 2003 at 11:35 AM
Great :-)
eric501 ( ) posted Fri, 26 September 2003 at 12:07 PM
I'm glad I'm not the only one with this problem.
xoconostle ( ) posted Fri, 26 September 2003 at 12:15 PM
Has anyone contacted DAZ? I wonder if they know?
Firebirdz ( ) posted Fri, 26 September 2003 at 3:48 PM
DAZ3D ( ) posted Fri, 26 September 2003 at 3:57 PM
Attached Link: http://free.daz3d.com
This has now been fixed. Everything should be fine now, you can just go back and redownload it you want. Thanks, Steve Kondris DAZ Productions, Inc.
Marque ( ) posted Wed, 14 January 2004 at 9:43 AM
Too bad I didn't re-download it while I had the chance. Didn't know there was an issue until I just tried to use them. Have an email in to them to see if I can get the update. Marque
