You must use the double checkmark and neither double-click or use the single checkmark. Single click = double checkmark. Really really obvious! (NOT!) Anyway doubleclicking replaces the character. When the genitals are loaded, use "conform to" and conform them to Mike.
You mean the Mike3 Genitals are a seperate character? Very interesting. I haven't gotten Mike3 yet because of all the negative PR it has gotten here in the forums and elsewhere. Was thinking of placing my order this weekend to get in under the price hike deadline. Soooo...if you texture him you also need a seperate texture/bump for the gen to match? What a pain not to mention an extremely bloated runtime folder. MAT files, texture/Bum files, inj and rem poses.......God how big a hard drive will I need with this darn series og Mil upgrades? I got Vicki3 and found it pretty rough on system. Mike3 will be the same. Vicki3 is parked while I use Vicki1/2 figures. Maybe I shouldn't get Mike3!?
Mike3 doesnt seem to be such a ram hog as V3...at least he seems to load much quicker...why that is, I have no idea, but if they can come up with an upgrade for v3 the lets her load as quickly.... Yes the M3 genitals are a seperate character (like most of us men, some women would say)...I suspect it is to allow less deformation of the pubic area when mike3 is used sans genitalia and to allow greater poly count on the genitalia. the original morphs (gen) and textures are pretty disappointing, but there may be enough there for our more talented morph artists to work with. Scarab
Actually, the reason for the lack of genatalia on the base figure is because of the way Poser uses the Genitals On/Off switch. In order to make it a multiple-part, fully poseable limb (so to speak), the team was forced to make it a separate figure. When using Geometry swapping (such as the genital switch), Poser doesn't much like emtpy body groups, and will often just display the alternate object in it's stead. for this reason, the team was unable to make it part of the figure... not because they couldn't pull it off, but because of Poser's limitations.
could somone please explain how to add the genitaila onto mike 3.0 as it is seperate but when i create character than try to put genitals on it leaves just the genitals and no figure please help thanxs
