Attached Link: http://www.unelmahevonen.com/share/
Great work Tiny - thanks! Here is a working link ;-)BTW, I did some things with your beautiful mane (see picture) cause I wanted it to "fall" the right direction when neck was moved. And I was going to use it. But when I finally got the hang of the hair room so I figured I go for that. I'm redoing it all (again)!
Attached Link: http://www.poserpros.com/forums/viewtopic.php?p=7784&highlight=#7784
NightFlyer: Cybermonk gave me the link to where the MorphSquisher can be found. It's at the Poserpros forum. One must register first, then click the link and you get straight to the thread. -------------- *And* did you see the very good Python script that Ockham did? It'll do your animation renders more or less automatically. Save as images, continue with next pz3 file and so on.Gravity is one of the issues I'll address when I rebuild the conforming mane. Probably with bodyhandles.
But I doubt that it'll ever be as good as the dynamic-hair manes that can be created in P5. Especially for animation.
Unicorn Run (MPEG format, 2.6MB)
Attached Link: http://http://www.unelmahevonen.com/share/
Finally I'm able to contribute with a little something. The angry ears for the Poser horse. Not perfect but looks ok from all directions. I also have a couple of other morphs at the location.All obj files squished with MorphSquisher. Incredible
tool!
The horse is modeled from the Ultimate horse (Collaboration by Lyne's Creations, Kacia & Bloodsong.
Texture from Lyne's creations.
Model and texture not included of course.
Hope you like it. :o)
