Vue F.A.Q (Last Updated: 2024 Nov 21 4:12 am)
You're right, it appears to be some sort of graphic representation of the ground plane. If I select the move tool and I change it's orientation to the camera, though if it is an infinite plane I don't understand why being able to move it would matter. Wouldn't moving the camera make more sense? If there is no terraine object in a scene is there really any ground at all.
A terrain object is different to a ground plane. Think of the ground plane as a sort of base line reference point. If you delete the ground plane and load or create a terrain object, depending on your camera viewpoint, the terrain might appear to be floating in mid air. The ground plane gives you nice simple geometry to avoid this.
Okay, thanks, I never saw it when I was able to use any of the 3D modes. So I guess my software is working okay like this, but I see a new video card in my future because I don't like working in wire frame. So if I were doing a space scene or just a cloud scape deleting the ground plane would be the way to go?
