Sat, Dec 28, 8:16 AM CST
Subject: Transparency problem
tresamie ( ) posted Tue, 07 October 2003 at 9:42 PM · edited Sat, 28 December 2024 at 8:14 AM
Hi all, I am working on a new image, and have run into an problem. I have put an image onto a 2d plane and inserted it into a scene, and parts of the plane should be transparent, but I can see the edges. I will upload the image and the settings here. Can anyone help me out? Tres
Fractals will always amaze me!
tresamie ( ) posted Tue, 07 October 2003 at 9:43 PM
The photo.
tresamie ( ) posted Tue, 07 October 2003 at 9:44 PM
The Material Editor screen shot.
tresamie ( ) posted Tue, 07 October 2003 at 9:45 PM
The Photo Editor screen shot.
ocddoug ( ) posted Tue, 07 October 2003 at 9:50 PM
You might try applying the texture to a lattice or a terrain, that way you can control how big it is.
tresamie ( ) posted Tue, 07 October 2003 at 9:56 PM
It's not the size that's the problem, it's the fact that the plane is not turning completely transparent. If you look against the sky, you can see the corner edges. I want it to be completely transparent, except for the 'smoke'.
mboncher ( ) posted Tue, 07 October 2003 at 10:21 PM
The only problem I can address is that your image is bleeding off the top. That right there is the major giveaway to it being a 2d image to me.
MuddyGrub ( ) posted Tue, 07 October 2003 at 10:29 PM
Try hitting the "copy" button on your first square in the picture dialog window (above), then use "paste" button on the second square to insert it into the alpha channel. The smoke picture should now be in both pictur boxes. Good luck!
Rochr ( ) posted Tue, 07 October 2003 at 11:43 PM
Attached Link: http://www.subspacegraphics.com/transmaps.html
Heres a small tut that might help.
Rudolf Herczog
Digital Artist
www.rochr.com
madmax_br5 ( ) posted Wed, 08 October 2003 at 12:51 AM
make sure to enable blend transparency in the arrow to the direct left of the first component window in the material editor. Make sure the alpha is loaded into the second window.
tjohn ( ) posted Wed, 08 October 2003 at 12:55 AM
It looks to me that the reason you can see the edges, is that the image itself runs to the edges. If you make your smoke image as shown here, it should fix your problem.
tjohn ( ) posted Wed, 08 October 2003 at 12:58 AM
Oh, and follow MuddyGrub's advice as well.
Kylara ( ) posted Wed, 08 October 2003 at 1:06 AM
I think she means in the black places she can see the edges too (I can). Make sure that the black in your pic is indeed black and not a very dark grey. If it is not 100% black you will see the edges. Increase the contrast of the photo in a 2D package to make sure to darken the dark places some more.
Andini ( ) posted Wed, 08 October 2003 at 6:31 AM
What MuddyGrub said is the problem. Try that and the problem will be solved.
Erlik ( ) posted Wed, 08 October 2003 at 1:07 PM
Seems to me the problem is something else. You have to put the actual image in the alpha channel. So that only the smokoe part is visible. Of course, Blend Transparency has to be enabled.
-- erlik
Erlik ( ) posted Wed, 08 October 2003 at 1:10 PM
Errr, yes, you have to move the lighter part away from the edge, too.
-- erlik
svenberg ( ) posted Wed, 08 October 2003 at 1:49 PM
tjohn has a point, the image runs off the square, try fixing that. If that doesn't work, and you are still convinced that the image just isn't going completely transparent, thenwhat you can do is go into a picture editor. let's say... even the basic windows paint program will do. paste the image, and then with the eyedropper tool thingy... put the cursor over a section without the white in it. a supposedly completely black prtion of the picture. copy the color of the pixel you have chosen. then open a new paint document, create a square, then paste the color onto it. then save it. when you go back into bryce, create a really big square, and cover your entire scene with it. in the materials editor, give it the copied color texture that you have created, and apply the same alpha stuff, transparency stuff... whatever, to it as you did for the picture. then when it is ready and seems to be just as transparent as the original picture, put the original picture square in the foreground of your scene, so that it is in front of your enormously big square. that way, where the transparent line of the original picture fails to disappear, the big square willcover up for it. *phew that was a long tutorial.... or you can take the original picture, put it into the paint program, and make a bigger square around it. that is the same color as the black parts of the original picture, and then apply that texture to one big square *i know, i know, i should've said that last tutorial in the first place, but i was way too lazy to erase the first one
tresamie ( ) posted Thu, 09 October 2003 at 12:09 PM
Whew, thanks all for these wonderful tips. I tried a number of things (all but this great tutorial, which I will save!) and please, don't laugh, but I found the problem. I was applying my image to the regular 2d plane, and not the leonardo guy primitive! As soon as I switched to him, the transparency worked perfectly! I didn't even realize that he was an object! Thanks for all your thoughtfulness. Tres
