Mon, Jan 6, 11:20 PM CST
Subject: HELP!! Poser 4/5 freezes after importing a new prop
DistantWorlds ( ) posted Tue, 07 October 2003 at 7:01 PM ยท edited Tue, 31 December 2024 at 3:57 AM
I recently made a new pair of sunglasses for one of my models, however when I try to render it in P4 or P5 as image both freeze or the model's texture shows errors appearently originating from the bump maps (at least the image map is rendering correctly up to 40% after the Bump Map has been deleted). If anybody knows this issue and a solution, please let me know! =(
DistantWorlds ( ) posted Tue, 07 October 2003 at 7:05 PM
I almost forgot to mention: After I imported the sunglasses prop as OBJ, assigned Materials to it, and saved it as prop it's invisible the next time I start Poser 4/5 but not when it's saved together with the model as character - however when I try to render the character, the above mentioned error occurs! =(
mikes ( ) posted Wed, 08 October 2003 at 11:23 AM
I've had this problem with the Mac version of Poser 4--the solution seems to be to delete the prop from the character, and then reimport/ reload it. This usually happens when a prop is imported, modified, and then resaved to the library. If you check the prop list for the character you will probably see the prop is listed twice.
DistantWorlds ( ) posted Wed, 08 October 2003 at 11:46 AM
I'll try that, thanks Mikes, but I checked the prop list and found now duplicate prop! <=)
