Actually I just had a similar problem recently with a figure I'm developing. It may not be the same since you can see the left forearm but here goes. It could be a cr2 file problem. in the character folder find the robots original .cr2 file (not the new one generated from saving to the library) and open it in wordpad or some text editor. look for a line similar to this one figureResFile :Runtime:Geometries:Cave Goblin:Goblin.obj There should be at least two such lines in the cr2 make sure BOTH of them point to the same .obj file located in the same place. If the first one is correct and the second one is different then it will never save right even though the origional will load correctly.
Is anyone else using the DAZ JICC 3000 robot? If I save this model as part of a scene or to the figure library, then load the scene or figure, all I can see is the left forearm, hand and fingers! The rest of the robot seems to be there (parts are listed in the menu and hierarchy editor), but they are not visible. Properties indicate the visibility attribute is set, and switching it off and on has no effect. Is this a bug? Is there something I can do to make the entire figure visible again? I'm using Poser 5. Thanks for any assistance. Mike
