Wed, Feb 12, 3:09 PM CST
Subject: problems with some V3 morph injections
JoeBlack ( ) posted Sat, 11 October 2003 at 7:51 AM ยท edited Wed, 12 February 2025 at 3:08 PM
Anyone else had problems where some morph injections work one minute, then they don't? I have encountered body morphs and teeth morphs that are flaky to say the least. For example, right now the "Voluptuous", "Rubenesque", "Pear Shape", "Nails Long" and "Heavy" morphs no longer work when you twirl their dials; nothing happens at all. With the "Nails Long" morph I've had to go to each finger tip and change the "pNailsLong" dial manually, which does work. I've also encountered morphs that don't work at all, namely some of the "Teeth" morphs that were added by the teeth update: "TeethUPBack", "TeethloRotx" to name but a few simply do not work at all, given V3 a buck teeth appearance! I've tried removing/reinjecting the morphs in question but it makes no difference. And I have no idea if other morphs are affected, I have yet to see. I apply these morphs in full-tracking mode, I have 1gb of ram and I have the 4.0.3 memory update. I don't know whether it's me or V3 that's at fault here. The total size of the PZ3 file is barely 50mb. JoeBlack
Simderella ( ) posted Sat, 11 October 2003 at 10:18 AM
Have you installed the SR1.1 updates for the base, head & body morph paks?
layingback ( ) posted Sat, 11 October 2003 at 12:16 PM
Sounds like the ERC morphs aren't working. Are you sure that V3 was the FIRST character loaded into the scene since you started that scene? If not, then the ERC/FBM morphs will not have been injected correctly. Deleting earlier loaded characters won't fix it either. Either start with V3 as first figure, or, implement Figure Independent Injection (see post in Poser Tech).
