Sat, Jan 11, 5:15 AM CST
Subject: I need an expert poser in here please!
PandaPride ( ) posted Sun, 12 October 2003 at 7:24 PM ยท edited Mon, 23 December 2024 at 2:36 PM
I need to know exactly what "INJ." and "REM" are suppose to do, and why aren't they working in my poser? from what I am getting it meants inject something and take it out, like the muscles etc of the body morphs I have for both Vicky and Mike. But they aren't working, any suggestions? --thanks Essie
dialyn ( ) posted Sun, 12 October 2003 at 7:29 PM
Inj injects the orphs. Rem removes them. Then you use the parameter dials to adjust them.
PandaPride ( ) posted Sun, 12 October 2003 at 7:34 PM
thank you!
Lyrra ( ) posted Sun, 12 October 2003 at 8:01 PM
INJ and REM pz2s add or remove morphs to specific models. They cannot be moved from the folders they install in, the geometry they refer too cannot be moved, and they ONLY work on the model they are made for.
PandaPride ( ) posted Sun, 12 October 2003 at 8:10 PM
I have been trying to use them on the models they are made for but for some reason, even when I do play with the dials it isn't working. Not sure whats up with that. --Essie
dialyn ( ) posted Sun, 12 October 2003 at 8:12 PM
Are you using Poser 4 or Poser 5??? Which model are you using???? The more specifics, the better the answers to your questions.
PabloS ( ) posted Sun, 12 October 2003 at 11:39 PM
If I'm not mistaken the primary dials are on the "body." Is it those that aren't working?
PandaPride ( ) posted Mon, 13 October 2003 at 8:28 AM
I have the inj and rem for Vicki 3 and mike 3. I am using them on those, and yes i am using the body dials. After I inject the +inj morph target thingie, I go to the dials, but the modification dials for the body for the injs do not appear there. I am using poser 5. Am I overlooking something? Or am I just being completely stupid about this? thanks for all your help --Essie
PabloS ( ) posted Mon, 13 October 2003 at 9:52 AM
If you have "body" in view and inject morphs, I've noticed that you won't seen 'em until "refresh" the dial window. I do this by going to another body part, then back to body (but there may be an easier way). Not sure if that's your problem but it might be worth looking into.
PandaPride ( ) posted Mon, 13 October 2003 at 6:15 PM
Thanks so much I'[ll give it a try. --Essie
