Poser - OFFICIAL F.A.Q (Last Updated: 2025 Jan 27 5:49 pm)
Attached Link: http://www.poserpros.com
For a proper telling of how this needs to be done, I suggest going to the PoserPros site (that Mendhi runs) and asking her directly.HI Folks, thanks for helping out with suggestions on how to get the hair to work in Poser 5. It does indeed have alot of the same problems as Koz's hair, as well as alot of the hair at Daz that has a similar construction method. It was developed prior to Poser 5, so it not really compatible, though I am told there are some work arounds that make it more compatible. It is why my page for it notes it is not designed to be compatible with Poser 5. I do not understand Poser 5's shader nodes well enough to be much help here either I am afraid, other than to know it does not work right there :(
I'm trying to render Elven Court hair in Poser 5, and not having any luck. I read on his site that it is not compatible with the Firefly renderer, so I tried the Poser 4 render option. This is grey and washed out, with no depth. I've tried using P4 lights, and going real bright, but no luck. Can anybody post the suggested steps to get the hair to render right? I was having the same issue with Sharkey's wings a while back and someone knew just what to do to fix them. Hoping, hoping! Thanks, Kfox
