Wed, Dec 25, 9:53 AM CST
Renderosity Forums / Carrara
Welcome to the Carrara Forum
Carrara Free Stuff here.
Subject: mystery of booleans
Animoottori ( ) posted Thu, 09 October 2003 at 2:16 AM · edited Tue, 24 December 2024 at 10:25 PM
I'm using C2 on Mac OS 9 and I'm having lots of problems with booleans in vertex modeller. The fact is that I cannot get the boolean substraction work. The program says I should select the base object (the one to substract from) with Command-button held down but it doesn't work. The point I select is just deselected.
Magik1 ( ) posted Mon, 13 October 2003 at 8:38 AM
Hellow HK This had me baffled for a while! Make sure that you are selecting ONE vertice with the selection tool and NOT the marquee tool. The selected vertice should now turn yellow and you can carry out your boolean subtraction. Good luck, hope this works for you.
Animoottori ( ) posted Mon, 27 October 2003 at 1:22 AM
GEE thanks butter! It did the trick! And many others too. I hadn't been able to do a sweep either in VM. I was sick for a while so I couldn't it until now Thanks again
