Poser - OFFICIAL F.A.Q (Last Updated: 2024 Sep 26 12:28 pm)
You can remove the morphs from Victoria 3 characters within Poser itself, using the REM poses, or delete them from the character files with Mason's Morph Manager utility (available in Free Stuff).
Do you have file compression enabled in Poser? The files are text-based, so they compress extremely well (sometimes as little as 15% of the original size). The downside is that Morph Manager and many other utilities can't read compressed files directly.
Hi everybody, i have been makin characters with v2, m2 and v3 (you know, morphing them, adding textures and hair and in some cases clothes) and then saving it to the library. I have no problems with it, the problem is that this way im running out of hd cause most of the characters i do with v3 took more than 100 mbs... Is there a way to delete for example the unused morphs (cause i usually load all the morphs to v3 and then i modify the dials) and save some hd? Any other ways to do keep the files at low size? Thanx
