I think that poser doesnt uses two processors... dont know... check curiouslabs i think i saw that in there... besides i will wait until the release to the public of the new 64 bits machines. If you can wait, Intel should make a best perfomance with rendering (at least in 3ds it does) but i dont know if poser is optimiced for intel or amd. Any good motherboard like Asus, Gigabyte or MSI should give you good perfomance
I am happy with my P4 2.8Ghz 800Mhz FSB and my Abit IS-7 Motherboard. Hyperthreading is supposed to be almost as good as 2 processors. If you're going to build a P4, make sure you have a power supply rated at 350 watts or better. More if you're going to build a dual-processor system. Also, get good quality memory such as Corsair, Mushkin, or OCZ CAS 2.
64 bit processing is a solid 10 months out before you'll see any real benefit. Yes, you can buy a 64 Bit Athlon right now, but it will be running on good old 32-bit Windows XP until Microsoft ships a 64-bit version of Windows. The 64-bit Windows is probably going to go into beta sometime next spring, so I would not count on a final shipping product until maybe late next summer (and I am being an optimist). That said, an Athlon 64 WILL run a 32-bit application at speeds similar to a 3.2 GHz P4 or and Athlon 3200+. However, when it comes to bang-for-the-buck, you'll not be getting anything in return for the price premium you pay for the 64-bit CPU (until late next year when your "new" system is almost a year old). I'm usually an "early adopter" when it comes to new hardware, but I'm going to wait for the 64-bit Windows to get released and through the first set of major bug-fixes before moving to 64-bit processors. In the interim, we'll also get some better info on Intel's "Prescott" 64-bit CPU. In the meantime, I think the best price-performance ratio is probably an NForceII Ultra chipset with an Athlon 3000+ CPU (400Hz FSB). The specific motherboard which has gotten the best reviews I've seen is the DFI NFII Ultra LANParty board, believe it or not. Drew
I compared Athlon vs Pentium price/perfomance for quite a while, before I made my decision to buy. I kept looking for reasons to buy Athlon. If I believed that the Athlon was a better buy, I would have upgraded to an Athlon. It looks like the Athlon 64 is going to be hard to beat, but it is expensive.
I am considering getting a new motherboard and CPU(s). I want a system that will allow faster render times with poser. Since poser doesn't use the GPU and only uses the CPU, I am thinking of getting a dual processor board. My question is weather Poser will be any better using a dual processor board as opposed to a single processor board? Would I be better off getting a faster single processor like a 3 GHz or dual 2.6 GHz? Thanks...
