Poser - OFFICIAL F.A.Q (Last Updated: 2024 Sep 19 3:46 am)
I'm not seeing anything. I do have a pop-up blocker on, but I'd see a sign that it was actively blocking pop-ups if there was anything going on. I tried Netscape and IE and can't find anything. I'm sure another Mod will wander by and test it as well. Hopefully it's a matter of something getting onto your computer from a different site and waiting a bit before spamming you with pop-ups. I've seen that happen before. Spybot and AdAware should take care of the problem. Cheers!
your browser has probably been hijacked.gator and xupiter are probably the hardest to get rid of once they are on your system.do a file search for these 2.if you find them on your system do a search on google for these 3 free programs,"hijackthis","ad-aware",and "spybot".if you dl them make sure you dl the updates also.there are a few good forums re:getting rid of browser hijackers.
Attached Link: http://www.javacoolsoftware.com/spywareblaster.html
you could try spyware blaster, It's supposed to stop spyware from being installed. I haven't had any spyware install itself since I started using it so it's doign something right :)hmmm .... There's not a huge amount we can do about such sites ... if we prohibited them, many people who cannot afford webspace would not be able to offer freebies. Mostly its the free webservers that are the culprit. Also, I use Netscape 4.2, so they don't affect me when checking sites. (obsolete browser ..works nicely as a popup blocker)
Removing IE is easy but you may need to make minor adjustments to other apps that depend or call upon it. WARNING! If you have never messed with your Registery before then proceed at your Own RISK!! You may seriously mess things up or even loose your ability to get back into Windozs!! 1) Click START->RUN and type 'Regedit' -> OK 2) IMPORTANT! FIRST BACK IT UP: FILE->EXPORT 3) Delete at least two Keys: a) HKey_Local_MachineSoftwareMicrosoft....(any thing saying Internet Explorer or IE ***NOT 'Explorer'!! b) HKey_Current_UserSoftwareMicrosoft....(any thing saying Internet Explorer or IE ***NOT 'Explorer'!! 4) Close Regeditor and open Explorer, find and delete the folder: C:Program FilesInternet Explorer 5) Reboot And it's gone! WARNING! If you have never messed with your Registery before then proceed at your Own RISK!! You may seriously mess things up or even loose your ability to get back into Windozs!!
I'd wondered where that came from. Until now, I figured (as most people who fall victim to it do) that I was the only one. Thanks for the info. I actually found it, as a virus, by accident on my weekly virus scan then investigated further. It had said that a ddm, or something like that, folder was in my program files on my c: drive. Lil buggers. ;) Stormy
Attached Link: http://www.accs-net.com/hosts/get_hosts.html
Ok. Got that cleaned out. I also updated my hosts file. Here's a link if you don't have one, or need an update.igohigh: nice explanation for people who want to start with... it is difficult to explain such things as registries in simple steps... for spywares, there is also addaware that is a nice thing, but some softwares will REFUSE to work if their associated spywares aren't in function. Then you still can block outcoming spywares with a firewall :) anyway what you said only prevent windows from using Ie as a default browser, isn't it ? I mean, sadly, IE still loads in memory at start of the computer, IE still take some 40mb space on your hard drive too, and many of its dll(such as the lousy pseudohtml help system) are still rooted into the system, so does the control panel applet (the source where most gator or spyware like to pollute..) I was talking about REMOVING :) (some ready to use software like 98lite free version does this like a charm). However it comes with a price: some other softwares, without any internet relevancy, will refuse to install, such as mediaplayer codecs (the installere needs ie, i dont know why, really.. but you still can install them manually), or 3dsmax 5 and paintshop pro 8. For me, the fact a 3d software or a paint software badly needs/requires some internet browser to be present (well not some, juste ONE, the worst in ater of stability and security) is totally puzzling to me. So far i do not use 3dsmax or psp8, so it is not very annoying. i think nothing without a price: either get annoyed by spywares, activeX scripts, some lousy trojans, and start popup and the like, not to mention other stability and memory issues, but being able to "do like everyone", and also install some high end programs, or be totally quiet about all those problems. I know it is a difficult choice for many... but it is another story and i think it goes outside the boundaries of Poser forum i think people may learn to be more exigeant and morethoughtful about themselves in the long term, instead of lazyly accept poisonned presents that tickle their self confort string but in fact have so many bad side effects... and for other people, remember: there is not very often now so called 'virus' in the strict meaning of the term according to virus programming gold age. Most of "annoying" softwares nowadays can be seen in startup registry keys, or by msconfig.exe, of by a task monitor, so in fact they are not VIRUSES, yet sure they are a real mess for unexperimented people. Hopefully, most of the time these 3-clicks vbscript generated pesky codes are easy to spot and remove when you know where to look...
Maybe a coincidence, but it's now being reported that a BANNER AD (!) was infected with Qhosts trojan at FortuneCity last week. It was removed as soon as it was discovered, but that was at least a few hours later. It symptoms matched those referenced in this thread. The exploit was for that M$ security hole of August (MS03-032), patched again in Sept (same #), and that was still open until the lastest patch this week in Oct MS03-040 (828750). So if you haven't updated in last week, time to do it again... Qhosts infection is the only known exploit of the 3rd iteration of M$'s bug, and the websites used by it have all been taken down. So it's no longer a threat, but how long before a copy-cat or variant breaks loose... And yet another reason to run an ad-blocker.
Is it just me or did someone sabotage freestuff to load a bunch of crap? 1) Anyone know how to get rid of the stuff it loaded into IE? 2) Shouldn't the freestuff review catch this before it goes online?
