Wed, Jan 29, 7:22 PM CST
Poser - OFFICIAL F.A.Q (Last Updated: 2025 Jan 29 7:12 pm)
Subject: Poser loading problem
SVicious ( ) posted Thu, 16 October 2003 at 8:00 AM ยท edited Wed, 29 January 2025 at 7:05 PM
When I load my poser program the window with the figure in it loads in the upper left hand corner and the only option I have is being able to scale the window. I can't move the window to the desired spot I want it in cause I can't clikc on the pz3 file name on the top left hand corner of the file. this has happen to me before and I don't recall how i fixed it can someone help me out here?
Kelderek ( ) posted Thu, 16 October 2003 at 8:03 AM
Set the user interface to "Factory State" in the preferences and it should get back to the Poser default interface you had when you installed it. It's a good idea to set a UI Dot with your favourite interface to be able to quickly get it back to order when something like this happens.
SVicious ( ) posted Thu, 16 October 2003 at 8:12 AM
nothing happened? do i have to restart poser in order for it to take effect
Kelderek ( ) posted Thu, 16 October 2003 at 8:45 AM
Yes, select "Launch to Factory State" and restart Poser and it should work. I don't have Poser on this computer, so I can't check the exact wording...
SVicious ( ) posted Thu, 16 October 2003 at 12:15 PM
that did the trick thanks kelderek
