Sun, Jan 5, 3:56 AM CST
Renderosity Forums / Animation
Welcome to the Animation Forum
Animation F.A.Q (Last Updated: 2024 Nov 13 3:03 pm)
In here we will dicuss everything that moves.
Characters, motion graphics, props, particles... everything that moves!
Enjoy , create and share :)
Remember to check the FAQ for useful information and resources.
Animation learning and resources:
[Animations]
Subject: Invisability
Bongo ( ) posted Thu, 01 July 1999 at 8:22 PM · edited Sun, 05 January 2025 at 3:50 AM
Does anyone know how the invisability feature in P4 works? Can you define shapes or areas on a character to be invisable? Can you animate invisability? (change the invisable area over multiple frames).
JeffH ( ) posted Fri, 02 July 1999 at 11:20 AM
You mean Transparency don't you? You assign it to the various areas of the body like the "Skin" in the materials dialog. -Jeff H.
Bongo ( ) posted Fri, 02 July 1999 at 3:05 PM
In P3 you can make body parts "transparent" - so what you're telling me is that in P4 you can make textures transparent? Could you make just part of the skin transparent?
JeffH ( ) posted Fri, 02 July 1999 at 3:19 PM
No, in p3 you can make parts Invisible. In P4 you can makes the skin look like it's glass or plastic "see-thru". You can do this for each material in the materials dialog or you can do it with a Texture Map. White areas of the map are opaque and from gray all the way to Black makes transparency. -Jeff H.
jdare ( ) posted Mon, 13 September 1999 at 10:29 AM
Bongo, just to clarify, yes, using a transparency map in P4, you can make just part of the skin invisible. - Jim
