Fri, Nov 29, 10:49 PM CST
Forum Moderators: Staff
Poser Technical F.A.Q (Last Updated: 2024 Nov 13 12:50 am)
Subject: v2 and v3 compatability issue....
atom123 ( ) posted Tue, 14 October 2003 at 9:28 PM · edited Fri, 29 November 2024 at 8:38 PM
hello peoples, i dont have victoria 3, but am in need of help w/ using her...... would a fbm made from a cr2 of victoria 2 created in poser4 w/ propack work on victoria 3 when someone is using poser 5? or.... is there reason that a fbm made on a pc wouldnt work on a mac?!? im having much difficulty in isolating what is causing the problem, so any help is much appreciated....
Little_Dragon ( ) posted Fri, 17 October 2003 at 5:07 PM
It probably won't work on Victoria 3, no matter which OS or version of Poser you use. Victoria 3 is built from a brand-new mesh. Victoria 1 and 2 morphs are not compatible with Victoria 3.
atom123 ( ) posted Fri, 17 October 2003 at 11:31 PM
thanks on that.
