Wed, Feb 5, 5:33 AM CST
Subject: More Props needed, and textures....help me
Azmyth ( ) posted Thu, 03 August 2000 at 4:47 PM ยท edited Thu, 30 January 2025 at 11:28 PM
I am trying to find a texture or prop or both for a sleeveless t-shirt. not a muscle shirt but a sleeveless t-shirt.... Also, I need a a prop and texture for long red hair with bangs...can anyone help?
Wizzard ( ) posted Thu, 03 August 2000 at 6:22 PM
Azmyth, Have you tried taking the conforming "T" and hiding the shoulder? the textures etc would still work... Just a thought... Cheers, Wizzard
jeffheater ( ) posted Thu, 03 August 2000 at 8:23 PM
Digital Babes has a new morph hair that comes with a blonde and brunette tex. map,by useing the blonde map and changing the material color you can come up with a pretty good red the link is http://www.vowel.or.jp/~kozaburo/dload/morphHair.html -Jeff
bonestructure ( ) posted Thu, 03 August 2000 at 9:28 PM
wizzard, can you tell me where in the menu the option to hide bodyparts is? I've never been able to find it
Talent is God's gift to you. Using it is your gift to God.
Wynter ( ) posted Thu, 03 August 2000 at 11:54 PM
Go to "objects" on your menu bar and choose properties. You'll get a dialog window giving you the option to check or uncheck for visible body parts.
Wynter ( ) posted Thu, 03 August 2000 at 11:55 PM
Of course select the body part first. :)
wander ( ) posted Fri, 04 August 2000 at 12:06 AM
An easier way to hide parts is to use the hiearchy editor and click on the eye icon next to each part you want to hide.
Wynter ( ) posted Fri, 04 August 2000 at 12:27 AM
Oh yes, right. I sometimes forget that. Its especially good if you're trying to hide lots of parts. Less tedious.
Wizzard ( ) posted Sun, 06 August 2000 at 1:41 AM
Heirarchy window... click off the parts you don't want.... another alternative... if you wish to try your hand at it. would be to make a transmap If I understand it correctly.. black "goes away" White full clear.. shades of grey... varying degrees of transparency... It'll take a bit of trial and error.. but well worth the experiance... ) Cheers, Wizzard
