Sat, Jan 11, 5:28 AM CST
Subject: V3 morph injects
PandaPride ( ) posted Mon, 20 October 2003 at 3:30 PM ยท edited Mon, 23 December 2024 at 1:52 PM
This is a big problem. I've tried roloading the v3 head morphs etc. and every time I go to click on inj for head morphs I am asked to locate the file, and once i locate the file I automatically get kicked out of poser, without warning. I also have the same problem with the motherhood package preganancy inj. morph. Does anyone have any idea why this is happening to me? --Essie
ghostship2 ( ) posted Tue, 21 October 2003 at 12:25 AM
the same thing happens to my V3 stuff as well. I think we're supposed to put the V3 stuff in the main runtime folder but im not sure and if i do that I want all my stuff in that folder so it's not a pain to work with.
KarenJ ( ) posted Tue, 21 October 2003 at 12:48 AM
OK 2 things spring to mind: Is the main "!DAZ" folder under the Library folder, not somewhere else? Also this should be in your main runtime installation if you're running P5, not linked from P4. Have you installed and run the V3 service release, and if you've moved folders, again copied the !DAZ folder across?
"you are terrifying
and strange and beautiful
something not everyone knows how to love." - Warsan Shire
PandaPride ( ) posted Tue, 21 October 2003 at 1:23 AM
nope running p5....this morphs are in my daz folder so i dont get what I'm doing wrong. No I havent even thought about going to look for the service release I suppose I should try that first. yes the main daz folder is under the library folder. Thanks for your help. -_Essie
PandaPride ( ) posted Tue, 21 October 2003 at 1:40 AM
the SR worked until I tried adding the v3 experssion morphs and then it just did the same thing to me as it had done before. any idea? thanks for your help again --Essie
KarenJ ( ) posted Tue, 21 October 2003 at 2:48 PM
I have had this lock-up problem with the expression morphs, come to think of it. I just can't remember what I did to fix it. There was also something to do with the teeth/gums morphs. Argh I can't remember right now. I don't think it's P5 specific. Right... ok searching my old files gives me 2 V3 SRs, one for head morphs and one for body. Did you download and install both?
"you are terrifying
